Zeitronix VS. AEM
Old Oct 14, 2008 | 09:51 AM
Rmrichards1385's Avatar
Rmrichards1385
Exclamation Zeitronix VS. AEM
Alright first of all for you sticklers and complainers, I used the search button, did a little research, but still dont have a clear answer! i have the turbonetics ST kit, gonna b controlled through a UTEC, just wondering which wideband I should get? The Zeitronix or the AEM. Heard good things about both, but have heard the AEM is more common, thus making it a little more compatible w/ the shops when we tune. Any recommendations?
Old Oct 14, 2008 | 10:35 AM
GTM's Avatar
GTM
Vendor - Former Vendor
Zeitronix.
Old Oct 14, 2008 | 11:35 AM
SpoilsofWar's Avatar
SpoilsofWar
+1, I would not buy another AEM wideband. It is not terrible, but the accuracy is questionable and it seems a lot of people have frequent sensor failures with them.
Old Oct 14, 2008 | 12:58 PM
Rmrichards1385
Thx Guys! I appreciate the info, I'll be gettin the Zeitronix wideband then!
Old Oct 14, 2008 | 02:00 PM
JonnyC's Avatar
JonnyC
Are you ever going to want to integrate your UTEC logs with your AFR readings? If so, then you might want to look into the Innovate LC-1 or the TurboXS Tuner, along with the UTI software (www.jeffsoftware.com).
If you're only looking for an external wideband, and the only tuning that will be done would be on a dyno that integrates their AFR readings with their logs, then the Zeitronix should work just fine.
Old Oct 15, 2008 | 10:13 AM
gothchick's Avatar
gothchick
I've been running an AEM on Bank1 and TXS Tuner on bank2 for almost 2 years. The AEM and TXS are always very close. So I have to assume the AEM is accurate. Couldn't say how long it'll last though, but I haven't had any troube with mine. They both use Bosch O2 sensors.
Old Oct 15, 2008 | 10:22 AM
booger's Avatar
booger
I have had both and the Zeitronix was the better wideband and is a boost and EGT display all in one . But the box is not the greatest looking display and you have to keep it out of the sunlight to see it . I mounted mine on the top of the dash to be in the line of sight . I could never see it in the day light so I built a shroud for it . I didnt think it looked good mounted anywhere else . I believe gauges look MUCH better !
Old Oct 15, 2008 | 10:44 AM
wannabuy350z's Avatar
wannabuy350z
Inoovate gives your the most range to minimize guessing under rich conditions
Old Oct 15, 2008 | 12:43 PM
SmallTuner's Avatar
SmallTuner
tuner pro is the best for UTEC users.
_koubie_
Sep 20, 2015 06:34 PM
