What cams to use for a built motor with greddy TT?
Old May 1, 2009 | 06:48 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
I use the gtm turbo cams with bc valvetrain. Love them
Old May 1, 2009 | 07:10 AM
coachk's Avatar
coachk
OP...sorry for screwing up your thread last night.
I have the JWT C8s... excellent for top end. Pretty radical cam with a pretty radical idle. I love mine
Old May 1, 2009 | 09:26 AM
copec's Avatar
copec
Hey Alberto, have you posted dynos of your current setup? (I couldn't find some with a search) I would like to see the comparison of curve from before to after.
Old May 1, 2009 | 10:26 AM
craigo'sznprgrs
That's top secret classified information. You sir, do not have clearance for such documents.
Old May 1, 2009 | 10:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I have not posted dynos, dont plan to sorry!
Old May 1, 2009 | 10:44 AM
coachk's Avatar
coachk
Dyno #'s are for sissies....Bert get that thing back on the track
Old May 1, 2009 | 11:46 AM
copec's Avatar
copec
Its not that I'm all about the numbers, I just like to see how certain specific modifications reshape the powerband--Its understandable though, some people don't care to focus on dynosheets out there on some forum.
The reason i asked was because the other dynos I have seen of BC stg 3 cams don't show a loss in the midrange, more like a loss for <3000rpms. So I was interested to see Alberto's dyno since he is a well known member of these forums (at least to me).
Old May 1, 2009 | 01:50 PM
Cass007's Avatar
Cass007
I was reccomended either the JWT C2s or the BC2s. I ended up with the BC2s because they were slightly less expensive and in stock. My builder and tuner advised me that either choice would be fine for the power levels I am seeking, FWIW.
Old May 1, 2009 | 02:03 PM
IslandZavage's Avatar
IslandZavage
what power levels were u seeking?
Old May 1, 2009 | 03:23 PM
ttg35fort's Avatar
ttg35fort
Professional
I'm envious... I hope to be there with you with the JWT C8 cams. Got to sell my JWT C2's first.
Old May 1, 2009 | 03:29 PM
JZurita's Avatar
JZurita
I have JWT C2 cams in my rice burner.
Old May 1, 2009 | 03:36 PM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by Z1 Performance
The advertised duration and lift #'s don't give you the full picture - those are largely marketing excercises. Start by talking to the guy building your engine, and head down to the library, the bookstore, etc and start studying what makes the cam work, and why it's relationship to the above engine characteristics makes or breaks the overall result. It will seem like alot of info to digest, but to truly make an informed decision, knowledge and understanding are your best friend.
You are correct in that the duration and lift numbers don't give you the full picture; there is alot more going on with a cam profile. Nonetheless, duration and lift are indeed important.
You are also correct about doing proper research. If anyone is interested in comparing two particular cams, call the manufactureres of those cams. I spent an hour on the phone with Jim Wolf on Thursday discussing my new build and my goals (JIM WOLF KNOWS HIS SHIAT ABOUT CAM DESIGN......) I have never spoken with BC, so I can't opine about his knowledge.
For my new build, Jim and I discussed the C2's and the C8's. Although the JWT C2's worked great with my Greddy's, now I definitely want the JWT C8's for my new GTM 4.0L stroker and Stage 3 TT setup.
Old May 1, 2009 | 04:13 PM
doug's Avatar
doug
I haz GTM Turbo Cams
Old May 1, 2009 | 05:39 PM
ttg35fort's Avatar
ttg35fort
Professional
Sam also recommends I use these. I don't doubt that they are great cams, but the JWT C2's have performed so well for me, and Jim Wolf blew my mind with how much he knows about cam design, that I am really lusting over the JWT C8's.
Old May 1, 2009 | 09:53 PM
eltness350's Avatar
eltness350
The Untouchable
http://s70.photobucket.com/albums/i1...g.flv&newest=1
heres what the bc stage 2idle will be like...hope this helps
Old May 1, 2009 | 10:37 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I forget... What are the specs for the C8? IIRC, they are 272 duration and might be comparable to the BC Stage 3.
Old May 1, 2009 | 10:55 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I like big cams GTM Stage 3 (288's) here
Incase anyone wanted to know what the power curve would look like:
-George
GT Motorsports
Old May 1, 2009 | 11:47 PM
  #38
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by George@GTM
I like big cams GTM Stage 3 (282's) here
-George
GT Motorsports
Nice power curve.
Can't wait to get my GTM 4.0L with the Stage 3 turbo kit on that puppy.
Old May 1, 2009 | 11:57 PM
  #39
ttg35fort's Avatar
ttg35fort
Professional
For reference, here is a comparison of various BC, GTM and JWT VQ35 cams stage 2 and up.
EDIT: I corrected the numbers for the overlaps at 0.050" lift for the JWT cams. These numbers assume the same profile for the front and rear of the cam lobes.
BC Stage 2 (VQ35DE)
10.82 mm Peak Lift
222 deg. Dur. at 0.050" lift
264 deg. Adv. dur.
??? deg. Before TDC Intake Opens
??? deg. After TDC Exhaust Closes
??? deg. Adv. Overlap
??? deg. Overlap at 0.050" lift
JWT S7R (VQ35 RevUp)
11.43 mm Peak Lift
225.5 deg. Dur. at 0.050" lift
262.5 deg. Adv. Dur.
5.25 deg. Before TDC Intake Opens
5.25 deg. After TDC Exhaust Closes
10.5 deg. Adv. Overlap
No Overlap at 0.050" lift (-26 deg.)
JWT C2 (VQ35DE)
11.58 mm Peak Lift
225 deg. Dur. at 0.050" lift
261 deg. Adv. Dur.
7.5 deg. Before TDC Intake Opens
18.5 deg. After TDC Exhaust Closes
26 deg. Adv. Overlap
No Overlap at 0.050" lift (-10 deg.)
GTM Stage 2 (VQ35DE and VQ35DE RevUp)
11.00 mm Peak Lift
232 deg. Dur. at 0.050" lift
272 deg. Adv. Dur.
BC Stage 3 (VQ35DE)
11.55 mm Peak Lift
234 deg. Dur. at 0.050" lift
272 deg. Adv. Dur.
JWT C8 (VQ35DE)
12.01 mm Peak Lift
235 deg. Dur. at 0.050" lift
272 deg. Adv. Dur.
13 deg. Before TDC Intake Opens
24 deg. After TDC Exhaust Closes
37 deg. Adv. Overlap
0 deg. Overlap at 0.050" lift
JWT C8R (VQ35DE RevUp)
12.01 mm Peak Lift
272 deg. Adv. Dur.
10 deg. Before TDC Intake Opens
10 deg. After TDC Exhaust Closes
20 deg. Adv. Overlap
No Overlap at 0.050" lift (-17 deg.)
GTM Stage 3 (VQ35DE and VQ35DE RevUp)
11.50 mm Peak Lift
245 deg. Dur. at 0.050" lift
288 deg. Adv. Dur.
JWT C9 (VQ35DE)
13.11 mm Peak Lift
248 deg. Dur. at 0.050" lift
283.5 deg. Adv. Dur.
18.75 deg. Before TDC Intake Opens
29.75 deg. After TDC Exhaust Closes
48.5 deg. Adv. Overlap
13 deg. Overlap at 0.050" lift
Old May 2, 2009 | 12:02 AM
  #40
ttg35fort's Avatar
ttg35fort
Professional
George,
Wholly smokes, I didn't realize how much duration your Stage 3 cams had. No wonder Sam kept telling me to go that route. I guess I should have checked it out.
How do they idle? Please let me know.
How many degrees of overlap? Do you have a cam profile chart?
Actually, perhaps you can let me know what your overlap is both on your Stage 2 and Stage 3 cams. I'll put those in the chart posted above.
