what the...
Old May 19, 2009 | 11:12 AM
  #61
Car vs. Driver's Avatar
Car vs. Driver
I agree with Frankie ... if there were knock counts consistently appearing in succession, then I'd be a little more concerned.
Old May 19, 2009 | 12:13 PM
  #62
Chef-J's Avatar
Chef-J
Booooosstt!!
Oh I see bro. I'm starting things figure out. I will try get some pulls tonight. I'm adding a small piece between my exhaust pipe now, hopefully that will help back pressue1.
Originally Posted by frankie945
thats one thing great about the utec it pulls timing when it picks up knock. Dont worry ur motor is not going to blow. Sometimes 1 knock count is just engine noise. I dont know were your knock threshold is set at.
I would like to see a 4th gear pull if possible it will tell us more.
Old May 19, 2009 | 12:20 PM
  #63
Car vs. Driver
Stop what you're doing ... with a centrifugal SC, you do NOT want to add back pressure. Think about it, with the blower you're throwing MORE exhaust than stock so you already have added back pressure vs stock simply based on that fact.
The perfect world is a free flowing exhaust with appropriate scavenging and velocity.
So, unless you're doing something related to one of those two .... just stop.
To be honest with you, you'll see the biggest benefit from a properly designed collector that promotes scavenging and increases velocity. By adding restrictors or smaller diameter pipes, you'll have velocity on the opposite end, but you're making the pump on the sending side work harder (in this case, your pistons).
People tend to complain about power loss when opening up their exhaust on some cars, that's because the collector is poorly designed and scavenging isn't happening and there's no velocity.
Moral of the story ... back pressure = bad. Scavenging + Velocity = win.
Old May 19, 2009 | 12:41 PM
  #64
frankie945's Avatar
frankie945
^ he is right leave your exhaust be. A little backpressure does help though in somecases.
Waiting for another log try to get it in 4th if u have a safe place to do it.
Take it up to 6400 rmps at least in 4th.
you baby it too much lol
Old May 19, 2009 | 12:55 PM
  #65
Chef-J's Avatar
Chef-J
Booooosstt!!
Dave,
Too late, I already cut it. Lol but I just thought, have headers and 2.5 hfc and 2.5 true dual flows too much air(since it feels like hard to build boost). Eh?? If it does feel weird or makes worst I will go ahead put the diff custom pipe.
Frankie, you funny man hahaha
Old May 19, 2009 | 04:09 PM
  #66
str8dum1's Avatar
str8dum1
you have to stomp on the gas tp get a proper log. just get on the highway real slow in 3rd. I always start my 3rd gear pulls from 2000 rpms and run them up to my redline.
you need to do a log like that to get a feel for all the load columns.
Old May 19, 2009 | 05:07 PM
  #67
Car vs. Driver
Originally Posted by Chef-J
Dave,
*facepalm*
Dude ... seriously, put it back the way it was.
You will never feel that sudden surge of power like you do in a turbo, so make sure you don't have that expectation (sounds like you do). With an SC, it builds power in a linear fashion, I mean ... look at your dyno graph. It's looks and will feel exactly like an NA car with tons of power.
Trust me, you're doing more harm that good by introducing back pressure.
Go back and read my post again.
Old May 19, 2009 | 05:22 PM
  #68
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by Car vs. Driver
*facepalm*
Yea, anyway now i have to go back...lol They messed it up, i wanted to try how sentry's setup. I read from his thread he said that sounds much more like Z...
But oh well i dropped it off and i went to startbucks real quick when they doing a job...and what they did is they just added small pipe between a pipe..like H pipe...i was like..ok. They were closing time so no time to fix it...I gotta go back tommorow morning and put it back way it was...
Now my car making a weird noise at 2000RPMs haha. Funny tho you low down the window you don't hear it
Old May 19, 2009 | 07:12 PM
  #69
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
chef,
care to explain to me how to me how to upload logs? and read them? or set them hehe im such a noob at this.
Old May 19, 2009 | 07:40 PM
  #70
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by Vas@Extended
chef,
LoL i'm noob but i know how to do that much lol
1. connect Utec
2. go to data logs which 1 - 6 ( I press 1 )
3. Then you will see whole bunch numbers moving
4. Go look where file, edit view call transfer help
5. click transfer, you will see "capture Text"
6. once you click it, you will get a box pop up. You can name the file..( just go ahead click "OK"
7. after click ok, you are back to the data logging screen
8. Now you are ready to go, before make a pull you press space bar to start, after pull press space bar to stop
9. then go back to click " capture text ", you will see you can click "stop"
Edit:
ALWAYS ENSURE THAT CAPS LOCK IS OFF!!
“w” or “i” moves cursor up
“a” or “j” moves cursor left
“d” or “l” moves cursor right
“s” or “k” moves cursor down
“TAB” moves cursor down
“ENTER” selects or inserts
“CTRL” and “SHIFT” plus other keys are used for several functions
“CTRL and x” typically exits the Menu
“ESC” typically cancels a selection
“SPACE” starts and stops the data logger
Old May 19, 2009 | 07:43 PM
  #71
Vas@Extended
So just connect the utec via the cable to your computer? my tuner did it i have no idea.. when I connect it.. nothing pops up? as in , it dooesnt read it? lol
Old May 19, 2009 | 07:47 PM
  #72
Chef-J's Avatar
Chef-J
Booooosstt!!
Gotcha, so you still haven't log on Utec then? am i right? I stuck at that too. But str8dum1 and frankie945 helped me to log on
Send you my number
Old May 19, 2009 | 08:45 PM
  #73
LegionnaireZ's Avatar
LegionnaireZ
Oh, and I forgot to mention. Welcome to the land of FI. Where any day without a problem, minor annoyance or SES light is a glorious one.
Keep your wallet open
Ugh... i've just been lurking around... I'm expecting to be FI... it is sounding like an everyday headache... sweet...
I get the avatar now...
Old May 19, 2009 | 08:51 PM
  #74
Chef-J's Avatar
Chef-J
Booooosstt!!
It's all luck luck bro...
Old May 19, 2009 | 09:16 PM
  #75
LegionnaireZ
well fortunately my luck with my N/A Z is great *knocks on wood* it dynos higher than average bone stock, no issues with the motor... I'm hoping that buying the kit wasnt a bad decision... if i have to fix something every week, i have a feeling it'll get old quick.
Old May 20, 2009 | 03:48 AM
  #76
Car vs. Driver
Vas, you need the USB drivers any Hyperterminal to connect to the UTEC. It's all in the instructions manual and you can download the drivers from TurboXS.
Old May 20, 2009 | 03:51 AM
  #77
Car vs. Driver
LOL. It isn't that bad man, don't let me scare you out of it. I love being a FI.
Old May 20, 2009 | 04:35 AM
  #78
Chef-J's Avatar
Chef-J
Booooosstt!!
USB cable FTW!!!
Old May 20, 2009 | 04:51 AM
  #79
Vas@Extended
I dont have the usb cable.. well sorta lol.. I have the old pin wire cable thats connected to a USB adapter > to my computer... Should I still get the USB driver? or do I need a complete USB cable
Old May 20, 2009 | 05:23 AM
  #80
drewk's Avatar
drewk
It happens to me sometimes, when I have a quarter tank. Its a fuel cut off. From the car jerking back. At least thats what my tuning shop told me.
