Engine Break in process, help.
Old May 24, 2009 | 04:59 PM
streetzlegend's Avatar
streetzlegend
Default Engine Break in process, help.
Sup all, I have been doing some research on whats the best way to break in a newly built motor and still cant get a straight answer.
How do you guys recommend I go about breaking in my motor.
Its a vq35 with Wiseco pistons, eagle rods, acl bearings, built for boost. I dont have an engine builder to ask (iv been told alot to ask my builder), but I built it myself.
So far iv let it idle for a few minutes, let it warm up, changed the oil, after that I put about 10 miles on it, varying rpm and gear, trying to not keep it at a constant speed/rpm. What other advice do you guys recommend, is it ok to let it go into boost? should I be doing any WOT quick burst yet? should i take it easy for certain miles. I just need guidance as how to go about this. Like what steps to take and at what miles do what. etc...
Thanx in advance.
Old May 24, 2009 | 05:09 PM
Italianjoe1's Avatar
Italianjoe1
Thanx in advance.
A lot of it depends on what rings you are using and how the cyl walls were prepared. Hard to suggest something without knowing that. Also what oil you are using, never break in on synthetic oil.
In general, it's ok to do some full throttle bursts, but keep the rpms down. Loading the motor, and then backing off in gear and building good vacuum can help seat the rings.
I'd give it a couple hundred miles of gradually increased pressure, don't be afraid to step into it, but don't twist it up to redline. After you get some time on it, change over to whatever oil you are actually planning to run and have at it.
Old May 24, 2009 | 05:44 PM
350 Rookie's Avatar
350 Rookie
non synthetic oil for 4k miles. After that, do w/e. Its very simple.
Old May 24, 2009 | 05:52 PM
Volk350's Avatar
Volk350
drive 1000 miles on it under 3k rpm to be extremely safe and make sure everything is broken in properly, is it on boost yet?
Old May 24, 2009 | 06:09 PM
doug's Avatar
doug
you don't have to stay under 3000 rpms.. just don't apply a great amount of throttle.. you should vary around the RPM range.. and it should be for at least an oil change.. 3000 miles.. give the rings some time to seat.. a little boost is also ok.. just don't go flooring it with your foot pressed at 100% throttle
Old May 24, 2009 | 06:13 PM
Volk350's Avatar
Volk350
thats why i put "extremely", not knowing if its on boost yet or not...because thats one of the safer ways to break it in....but yes i do agree with you though when it comes to beating the engine up right away
Old May 24, 2009 | 06:17 PM
doug's Avatar
doug
i think the most horrible experience of driving my car was breaking in a new engine.. the anticpation sucked
Old May 24, 2009 | 06:20 PM
westpak's Avatar
westpak
SFZCC
go crazy http://www.mototuneusa.com/break_in_secrets.htm
Old May 24, 2009 | 06:28 PM
doug's Avatar
doug
Originally Posted by westpak
Intresting.. always heard about breaking in bike engines hard... i broke in my 07 GSX-R 1000 hard since it came off the truck.. 13 miles.. never did it with the car though
Old May 24, 2009 | 06:31 PM
doug's Avatar
doug
Gus.. quick question.. that link is for brand new cars.. would that still apply if you had a built motor with over 600 whp? or is this link under the assumption the car is a brand new engine from the factory with under 300whp? running 600whp would bring more cylinder pressure right? would that affect the seating of the rings? or would the same theory apply?
Volk350's Avatar
Volk350
ha that anticipation must have eaten you alive!!!! but yes that is a rumor i heard too that you should beat the hell out of it right away, but i think thats just retarded....who knows i could be wrong
Old May 24, 2009 | 06:32 PM
streetzlegend
Yea i have that bookmarked and iv read it a few times, just was worried if that was a good method or not.
Right now im using penzoil 10w40 dino (because its on sale and its not a bad oil i dont think) also using a breaking additive with high zinc n phos..
Tomorrow im going to change the oil again and start driving it. Thanx for the tips guys, Im mad nervous when driving the car, dont know what to expects, its my first build.
Also, I have an auto and I have a manual switch for my torque converter, would it be a good ideal to lock up the TC during low rpms and acceleratel slowly, to load up the engine a bit?
Old May 24, 2009 | 06:37 PM
boostintt's Avatar
boostintt
i have 400 miles on my new built engine. so far so good will be boosting hard soon
Old May 24, 2009 | 06:40 PM
streetzlegend
How have you been driving?
Old May 24, 2009 | 06:47 PM
westpak's Avatar
westpak
SFZCC
well first time I had my new engine I broke it in easy not going over 4k for 1000 miles, the second time I had no patience, yes I had new rings the second time, so I did a little bit of a hybrid method. Drove it easy for a couple of hundred miles, then for a couple of hundred more I did moderate boost up to 5 psi and close to redline and coasting doing the boost and full vacuum and then I did this for a couple of hundred more going to 10 psi or so and then at 1000 went on the dyno and tuned for 15 psi.
I did have the benefit of having the car tuned for the boost levels on the first engine.
I do wish the dyno had been available like I have it now and I would have just spent a day on the dyno doing progressive pulls for a day or two and be done with it.
I have not met anyone that has done that method I quoted but I figured it would generate some discussion
Old May 24, 2009 | 07:20 PM
doug's Avatar
doug
i'm thinking if i bought a brand new car.. C6, M3, GTR.. i would have no problem doing it, because it would be up to the dealership to prove otherwise if something went wrong.. but after spending so much on a built engine and knowing there is no factory warranty.. i'm less reluctant to be the guinea pig.. which is why i broke in my bike hard.. because i know i had the factory warranty
Old May 24, 2009 | 07:22 PM
westpak's Avatar
westpak
SFZCC
good point, I know my butt puckers whenever I think something might be screwy with my car
Old May 24, 2009 | 07:26 PM
Madelinot's Avatar
Madelinot
I was easy, no bosst and only up to about 4000rpm for about 300 miles. Then I dropped the oil, put synthetic and started tuning it. I'm at about 1000 miles and so far so good. I saw 20psi on the gauge tonight, I still have some tuning to do... :-D
Old May 24, 2009 | 07:32 PM
350 Rookie's Avatar
350 Rookie
On my built motor. as soon as i hit 500 miles of no boost, i started racing it. lol
Old May 24, 2009 | 07:34 PM
streetzlegend
Lol, no patience i see. Thats how I am.
