built motor questions
Old Jun 13, 2009 | 02:28 PM
Heretic John's Avatar
Heretic John
Default built motor questions
Hey guys, im building my motor with wiesco pistons and eagle rods, however my question is, is it okay to use the std bore pistons 95.5 vs. using a 96mm bore piston. (also no .02 overbore on either option). thanks in advance.
Old Jun 13, 2009 | 02:34 PM
wannabuy350z's Avatar
wannabuy350z
depending on how cylinder walls are... milage and cylinder cross hatching. but your putting in new pistons and rings i would bore.
Old Jun 13, 2009 | 08:56 PM
Heretic John
but in my situation would you go with the 95.5mm or the 96mm bore?????
Old Jun 14, 2009 | 01:57 AM
wannabuy350z
you are kind of confusing, which is why no one has responded to you.
if you hone, bore your block go with 96mm, if you have a low milage close to perfect condition cylinder go with 95.5mm
Old Jun 14, 2009 | 05:21 AM
Zivman's Avatar
Zivman
even if they are in perfect condition, please mic the cylinders to know exactly what the cylinders are. just because the stock bore is supposed to be 95.5 doesn't mean that is what they are. In addition, you will run different clearances on an aftermarket forged piston that you will on an oem cast piston. the way a motor should be built is the holes should be machined to spec in reference to the specific individual piston going in.
In short, no, you should not buy stock bore pistons without knowing the exact condition and measurments of each cylinder.
Old Jun 14, 2009 | 06:38 AM
westpak's Avatar
westpak
SFZCC
this is something you should be discussing with a machine shop to get the right clearances
Old Jun 14, 2009 | 07:25 AM
boostintt's Avatar
boostintt
like everyone says, it depends on how many miles your engine has.. you can always take it to your machine shop, if you trust the guys there then ask them to inspect the shortblock and ask them if you go with just a cylinder hone, will the cylinder wall clearances be ok. mine came out a bit wide
Old Jun 14, 2009 | 09:09 AM
350 Rookie's Avatar
350 Rookie
Dude, forged performance is right there. Just call or drop by. This cannot be any easier for you. Those guys rock.
Old Jun 14, 2009 | 09:14 AM
boostintt's Avatar
boostintt
they'll lead you on the right direction!!
Old Jun 14, 2009 | 09:40 AM
Heretic John
yeah my bad im 2nd response was silly. i mis-read it.
im asking because i found a great deal on a NEW Wiesco 8.8:1 piston set with 95.5mm bore for like $600
also i got 104k miles on my Z. (yeah i know its alot.lol its my dd)
Old Jun 14, 2009 | 09:57 AM
ToastZ's Avatar
ToastZ
Your in Atlanta, right ?
Definitely call Forged Performance: 770-792-0202
Sharif and his team have built many (I have no idea how many, but its a lot) VQ Motors with a very high success rate.
Old Jun 14, 2009 | 10:04 AM
350 Rookie's Avatar
350 Rookie
dont buy pistons or anything just because you found it cheap. unles it was like 200 for 6 new ones but 600 is like arias pistons. Just wait and youll save money.
Old Jun 24, 2009 | 06:50 AM
jining's Avatar
jining
You confuse meee.... 95.5mm is stock bore and 96mm is the same as .020" over...
Fixxxercask
Nov 9, 2015 11:10 AM
