Cable TB swap
Old Jul 22, 2009 | 10:44 AM
KPierson's Avatar
KPierson
It would be cool to see a module made that took the throttle motor output from the ECU and generated an expected TPS signal to send back to the ECU. The ECU would then think it was controlling the throttle body and you could do whatever you want to the TB.
This would help if you were just trying to go with a cable system or if you wanted to recalibrate the DBW system and go with a stand alone electronic TB controller.
As long as you keep the two TPS voltages within the expected range going back to the ECU I don't see why this wouldn't be possible on an OEM ECU. The conversion wouldn't be too bad either, just a pulse width to analog voltage converter.
Old Jul 22, 2009 | 12:25 PM
Quamen's Avatar
Quamen
Thank you for volunteering to make one. I wiill more than happily purchase it and do some beta testing!
Old Aug 25, 2009 | 06:19 AM
Quamen's Avatar
Quamen
Does anyone know what cable throttle bodies have the same bolt pattern as the DBW one? Older Pathfinder?
Old Aug 26, 2009 | 07:31 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the aftermarket units (I got a 75mm) for the 4.6 liter Mustangs are very, very close. I'll post pics of mine soon, but I was able to just slot the holes on the tb and it worked perfectly with an unported Cosworth plenum
Old Aug 28, 2009 | 04:44 PM
Quamen's Avatar
Quamen
What engine management are you using?
I am going to be going with an Electromotive unit and either a mustang 75mm throttle body or a Vet 80mm. Most likely the Vet one soley because the TPS will be exactly what Electromotive recommends.
Old Aug 28, 2009 | 04:47 PM
Z1 Performance
Former Sponsor
Haltech
I'm not using a tps on my throttle body at all - no room with the cosworth plenum. TPS on mine is the sensor on the gas pedal. I also didnt want to hack up the plenum to get a bigger throttle body in there, and 75-76mm seemed to be about as big as the cosworth throat would accept
Old Sep 1, 2009 | 04:03 AM
Quamen's Avatar
Quamen
I decided to bite the bullet on Electromotive. I am putting my car in storage soon in order to start switching over. I will be sure to post a DIY thread on a cable throttle body conversion this winter.
Old Sep 1, 2009 | 04:52 AM
GreenGoblin's Avatar
GreenGoblin
looking fowrard to your progress and pics down the road.
Old Sep 1, 2009 | 05:16 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Curious, why did you choose the Electromotive? I'm all for doing something different, but it sounds like you are asking for more work/headaches when there is already a proven solution.
Old Sep 1, 2009 | 07:11 AM
Quamen's Avatar
Quamen
I have worked on them and installed them before. 928 Motorsports is a dealer for them also so I am able to get a good price and good local support.
I took a good look at Haltech and Pro EFI. Even though they are both amazing and proven systems, I feel they are not the direction I want to take with my car anymore due to some of the other things I am looking to do.
One of the other things that keeps popping up is electrical issues related to when NCR originally had my car in 2005 and blew the motor up. There was a number of things they did to my engine harness of which I was unaware of at the time and problems with the harness seem to keep popping up.
Old Sep 1, 2009 | 06:07 PM
tig488's Avatar
tig488
Originally Posted by phunk
is anyone boring out the stock throttle bodies? i think somebody used to a long time ago but it wasnt really needed back then... now theres probably a few cars out there that could use it. i would have mine done for sure.
iirc, Crawford had a bored TB on their shop car. he brought it up to Zdays back in 2005 when i went. They took quite a bit of metal out of it, i think the max possible before it falling apart.
Old Jan 18, 2012 | 11:20 AM
str8dum1's Avatar
str8dum1
bump for old thread. anyone have a cable TB? I figure I'd need a Q45 tb along with some sort of 70 to 90mm adapter.
My TB doesnt hold its calibration it seems. I reset it and its 0% at idle, after i drive it for a while, idle is like 3%, which starts to mess with my idle controller. If I have to replace my TB, I'm just gonna simplify and go to a 3" cable TB.
Already read that the 240sx pedal bolts right up, so it would only be like 150$ in parts to swap to a more responsive option.
Old Jan 18, 2012 | 08:48 PM
midz350's Avatar
midz350
I wanna see your build thread. You always coming with crazy ideas and I wanna see them.
Old Jan 19, 2012 | 04:07 AM
str8dum1's Avatar
str8dum1
Pretty easy to run a cable TB for a 2JZ swap. The motor already has the cable stops. HOw are you going to run the gas pedal? MOdified stock or use a 240sx?
Old Jan 19, 2012 | 05:29 AM
Dynosty's Avatar
Dynosty
I ran a cable throttle on the green 350z (per racing requirements, mech throttle only) and I would advise to use the stock throttle or upgraded electronic throttle (for example, LS based engine w/ larger throttle) for stock like idle and drivability. If you go to mechanical throttle be sure to add an idle air controller to the system (parts + wiring required) to get nice startup/cold idle/hot idle. We have changed multiple cars to mechanical throttle for various reasons like drag racing and individual throttle bodies and we modify the stock pedal every time. It is fairly simple with a little time and thinking outside the box.
Old Jan 19, 2012 | 05:41 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
I know of the VQ 240 swaps we have done, the 350z electronic pedal assy literally bolts to two studs on the fire wall exactly. I have never gone the other way(240sx pedal assy in a 350) but I imagine it will bolt right up and then just set a stop on the floor...
Old Jan 19, 2012 | 05:52 AM
Z1 Performance
Former Sponsor
Converting to the cable on my car was also straightforward, used the stock gas pedal, made a nice bracket, and it was done. You'll see how it needs to be once you're down there. My cable is super short as well, maybe 3-4 feet total, which helps overall response (though I never had a complaint with the stock drive by wire setup).
Can't see the point in swapping to a 90mm throttle body only to mate it to a 70mm adapter and neck it down that much. Defeats the purpose of the larger throttle body and creates potentially a worse bottle neck than a stock plenum has. The largest mine (Cosworth) would take was what we ended up with, which IIRC is a 75mm or 76mm unit.
Believe it or not, I've run all this time without any idle air control. Cold starts are the only negative.....I treat it like a carb'd car and just keep my foot on the pedal to about 1500 rpm till the 02's cycle, then it idles fine on it's own. It works fine with the a/c on, and hot start/idle has not been a problem. One of these days I'll get the Haltech or similar IAC setup in there, just haven't gotten around to it.
You'll also need to reconfigure your tps. I swapped wires around on the Haltech and flashed the stock ecu to not emit a TPS signal as I recall, as the Haltech looks for it in the usual spot otherwise. Can't quite remember the details though as it's coming on 5 years now since it's been done
Old Jan 19, 2012 | 08:14 AM
  #38
mw9's Avatar
mw9
great info and in for updates
Old May 6, 2012 | 04:48 PM
  #39
jdm5596's Avatar
jdm5596
anyone have a build thread with pictures and steps... im fixing to do a swap, but needing ideas on setups that work good.
my z is having problems when ita barely cool outside, will not full throttle until its hot outside. anx aatching the throttle position on my datalogger, its very slow when i hit the throttle wot. just got the car so im trying things out
Old May 7, 2012 | 06:31 AM
  #40
Dynosty's Avatar
Dynosty
This is not a small undertaking or for the weak of heart. Remember there is no idle air motor, so cold-start and hot driving will be impacted by removing the drive by wire. Also the stock computer will be very upset by this. I would suggest a Haltech ems as mandatory with the switch to cable. If you are trying to diagnose or fix a slow throttle response problem I would look elsewhere.
