apexi turbo timer help
Old Sep 4, 2009 | 02:56 PM
redman333's Avatar
redman333
Default apexi turbo timer help
I need help figuring out how to program my apexi auto timer. I can't find my manual. When I go into the menu it gives me things like 3n1, and 3L1, and 3H1. I'm assuming the lnh are high, low, normal but the numbers can change and I don't know what they mean. It doesn't seem to change anything when I mess with them.
Old Sep 4, 2009 | 04:30 PM
terps's Avatar
terps
Just set it up based off the times. There's afr settings but the stock ecus voltage is too low to really work. I got t set up for 60 secs and that's more than enough.btw the headlights won't turn off since it doesn't sense the door opening so
ake sure u turn them off manually
Old Sep 5, 2009 | 06:25 AM
redman333's Avatar
redman333
Actually my headlights turn off still. I always leave my lights on. They don't turn off right away though. It senses the stock 02 sensor to determine how long to stay on. What if I have a wide band.
Old Sep 5, 2009 | 12:27 PM
terps's Avatar
terps
I was told by my tuner that the o2 signal was too weak to accuratly work. Yah the lights will turn off eventually but after 5 mins or so. Maybe my tuner was just being lazy but apparent the sto k ecu voltage is 1 volt and the apexi need a minimum of 1.5 volts or something similiar to that. The general concensious is that turbotimers arnt needed(my gf got it for me so I installed it) but if you do use it 30 secs should be adequate
Old Sep 5, 2009 | 03:19 PM
redman333's Avatar
redman333
Well right now I'm getting a 0-5v reference on the timer now when I put it on af. Id just like to see how to change it so that the times change based on driving habits. Generally set mine manually, at 60 secs normal driving and 5 minutes if I've been driving it hard. Never had a problem with my turbo yet and have had it for almost 50k miles now so I figure ill keep doing it.
bcoffee20
Nov 19, 2015 06:39 PM
