question about Pathfinder rear cooling mod
Old Feb 24, 2010 | 08:03 PM
marcelz's Avatar
marcelz
Default question about Pathfinder rear cooling mod
can i just use the original thermostat?>
not install the second one come with the pathfinder kit?
Old Feb 25, 2010 | 05:47 AM
str8dum1's Avatar
str8dum1
you can set it up how ever you like.
i am using the thermostat.
Old Jun 7, 2010 | 11:09 AM
IslandZavage's Avatar
IslandZavage
wouldnt it be a better idea to replace it with one that will open sooner?
Old Jun 7, 2010 | 01:50 PM
BrazenZ's Avatar
BrazenZ
I think it opens around 150F, remember your radiator fans on/off switch ultimately controls coolent temps.
(I have mine in because the rubber gasket is attached to the thermostat, you could take the spring and valve out and just leave the housing and gasket.)
Old Jun 10, 2010 | 11:42 PM
bbs350z's Avatar
bbs350z
mine didnt come with a thermostat. im on my factory one, no issues
Old Jun 13, 2010 | 01:03 PM
BrazenZ's Avatar
BrazenZ
^^^ Did you use gasket sealer (liquid) or did you make your on gasket?
Old Jun 14, 2010 | 06:30 AM
nomyth46's Avatar
nomyth46
how does this cooling mod work?.............are we talking about just a colder thermostat that comes with the kit or does it have a second thermostat to install on the car?...so would the car running the stock thermostat plus a secondary?
Old Jun 14, 2010 | 06:35 AM
Glex25's Avatar
Glex25
Secondary that opens up to cool other parts of the motor
Old Jun 14, 2010 | 06:36 AM
str8dum1's Avatar
str8dum1
its an entirely new rear coolant pipe with a hose that attaches to a coolant port between the heads. stock, there's just a block on it, but with the pathfinder part, you take off the block and attach a hose.
supposed to give better coolant flow to the rear cylinders, since there's a more direct route. theres another thermostat in that new rear coolant pipe. I use it since thats how the engineers at nissan designed it. but its up to you how you want to do it.
My car warms up fast enough that it doesnt matter. By the time im driving for a bit all the stats are wide open
Old Jul 9, 2010 | 07:24 AM
specialist's Avatar
specialist
Any one have part number for these parts for this mod?
Old Jul 9, 2010 | 11:38 AM
Cass007's Avatar
Cass007
you can buy it as a complete kit from forged. its on their website.
Old Jul 9, 2010 | 09:09 PM
johnwigs's Avatar
johnwigs
maybe you should ask GTM about melting heads and this "pathfinder cooling mod"... there is a reason that it isn't used anymore on VQs...
Old Jul 10, 2010 | 05:44 AM
Cass007's Avatar
Cass007
Maybe you could send us a link or enlighten us on the knowledge you possess
Just the facts, no GTM vs FP BS required.
Old Jul 10, 2010 | 06:46 AM
captj3's Avatar
captj3
I'd be interested in this as well. Of course without the shop BS.
Old Jul 10, 2010 | 07:02 AM
Cass007's Avatar
Cass007
Maybe GTM should stop selling it too...
http://www.gtmotorsports.com/product...cat=275&page=1
Old Jul 10, 2010 | 07:28 AM
crsracing19's Avatar
crsracing19
at what point is this mandatory when you go fi? or is it only recommended for a certian hp range
Old Jul 10, 2010 | 05:11 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
melting heads you pop your hood and the heads are a big blob of molten aluminum
Old Jul 10, 2010 | 06:27 PM
Glex25's Avatar
Glex25
Delete double post
Old Jul 10, 2010 | 06:28 PM
Glex25's Avatar
Glex25
You mean blowing heads like this
Old Jul 10, 2010 | 08:23 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
^^^WTF is going on in those pics??
