that noise is normal?
Old Apr 13, 2010 | 06:51 PM
BOOCKER's Avatar
BOOCKER
Default that noise is normal?
Hey gus, i got a vortech supercharger from one member from here, i already installed, and it makes some internal noises. is that normal??
http://s28.photobucket.com/albums/c2...3042010007.flv
Old Apr 13, 2010 | 06:54 PM
Entaille's Avatar
Entaille
doesn't sound normal.
Old Apr 13, 2010 | 07:34 PM
whoojong's Avatar
whoojong
It's hard to guage over a video. The type of sound isn't normal, but it doesn't sound very loud, which may mean it's nothing. best way to check is to remove the COG belt, and turn the Vortech pulley by hand, it should rotate very smoothly. If it "catches' then bad bearings.
Old Apr 13, 2010 | 07:35 PM
- bigc -'s Avatar
- bigc -
At what RPM is your idle set?
Old Apr 13, 2010 | 07:37 PM
Lee R's Avatar
Lee R
Is your radiator cap leaking?
Old Apr 13, 2010 | 08:16 PM
BOOCKER's Avatar
BOOCKER
about 750
Old Apr 13, 2010 | 08:17 PM
350junkie's Avatar
350junkie
+1
I know they make some racket at idle, but I don't think it sounds like that.
Old Apr 13, 2010 | 08:19 PM
BOOCKER's Avatar
BOOCKER
no, i changed the coolant
Old Apr 13, 2010 | 08:25 PM
BOOCKER's Avatar
BOOCKER
Thumbs up
ok, i ll check it. so if it needs bearing, i can get them as a rebuild kit?
Old Apr 13, 2010 | 08:28 PM
350junkie's Avatar
350junkie
yup, sure can. Just contact the manufacturer of the blower and they'll be able to get you started on getting one.
Old Apr 13, 2010 | 09:46 PM
Mr_pharmD's Avatar
Mr_pharmD
thats normal. bump the idle to 900 and the rattle will go away.
Old Apr 13, 2010 | 09:47 PM
whoojong's Avatar
whoojong
Rebuilding the SC is not that hard, but you have to have a hydraulic press and some bearing pullers. http://superchargerrebuilds.com/ sells the kits, but i just reccomend sending it to them or to vortech.
Old Apr 14, 2010 | 06:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If it's just a rattle, it's probably the normal noises that the vortech makes. If it starts making an aweful metal on metal noise it's time for a rebuild.
Old Apr 14, 2010 | 07:30 AM
djamps's Avatar
djamps
I've seen Vortechs make funny sounds at idle but normal at non-idle RPM. Does it go away when revving it?
Old Apr 14, 2010 | 08:46 AM
CeBrwn5454's Avatar
CeBrwn5454
Doesn't sound normal to me.
Old Apr 14, 2010 | 10:18 AM
acg's Avatar
acg
Sounds worse than mine used to and mine idled around 750-800.
Old Apr 14, 2010 | 11:19 AM
BOOCKER's Avatar
BOOCKER
ok, im checking all the bearing of the pulleys, but i have another question, does any one know what should i do with this hose? cos at the vortech manual doesnt tell anything about it.
Old Apr 14, 2010 | 11:36 AM
Sharif@Forged
Forged Performance
There should be an extension hose and adaptor that runs to the back of the Vortech filter. Looks like you are missing a couple of pieces.
Old Apr 14, 2010 | 11:59 AM
BOOCKER's Avatar
BOOCKER
i got this hose
Old Apr 14, 2010 | 12:06 PM
350z006's Avatar
350z006
You interested in trading you stock blower for a more powerful Si Trim blower for about the same price as a rebuild?
https://my350z.com/forum/turbos-nitr...ale-trade.html
I don't care if your bearings are shot as I'll be getting the blower upgraded anyway...as long as you have the V2 blower and it has the CARB # on it...
BTW, this is what it sounds like...I had my blower fully rebuilt as well...
https://my350z.com/forum/7698885-post22.html
