600cc DW work with stock fuel system?
Old May 6, 2010 | 11:25 AM
tw8715's Avatar
tw8715
Default 600cc DW work with stock fuel system?
Hello, I will be getting the greddy 18g kit, and swapping the emanage for a Utec. I was planning on using the stock fuel system with a walbro and larger injectors, (as I heard the 440cc RC injectors that come with the kit MAY be nearly maxed out at the power im trying to achieve, which is ~400rwhp).
Few questions:
Firstly, can I even use the 600cc DW injectors successfully with the stock fuel system or are they too big?
Will I need need to modify the stock fuel pressure regulator for the walbro? Can it handle the pressure that the walbro puts out?
Old May 6, 2010 | 11:41 AM
captj3's Avatar
captj3
400 on a stock motor is no problem with the stock greddy injectors. 600cc is boarder line with a utec as far as hot and cold starts. You may have to floor the gas pedal when starting the car.
Old May 6, 2010 | 11:45 AM
jining's Avatar
jining
Walbro install, gotta modify a few things but should be ok with stock FPR I believe? : http://cj-motorsports.com/342install.htm
My 600cc DW's hot/cold start flawlessly with my UTEC, been boosted for 2.5 years
Old May 6, 2010 | 12:32 PM
350z006's Avatar
350z006
I ran RC 650's with my old stock setup no problem with my walbro set up via phunks DIY...ideally you would have a fuel return, but I had no issues with it...
Old May 6, 2010 | 02:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
DW600cc Injectors, Walbro fuel pump, plus fuel pump assembly modifications should get you safe stock block power with a UTEC. 400-450whp max depending on the dyno. Of course, for max safety do a basic return.
Old May 6, 2010 | 02:20 PM
DeatschWerks's Avatar
DeatschWerks
Vendor - Former Vendor
Thanks for the replies, guys!
With all of our larger injectors we do recommend that you upgrade your fuel pump, just to ensure that your engine is getting the fuel it needs.
TW, if your goal is 400-450whp, the 600cc's would be perfect, right around 80% IDC, too!
Chris
Old May 6, 2010 | 03:15 PM
tw8715's Avatar
tw8715
Awsome thanks guys
Old May 6, 2010 | 05:47 PM
streetzlegend's Avatar
streetzlegend
I have 600's with about low 30's in fuel pressure(at idle with vacuum applied) and 1:1 afpr, using emanage ultimate. Walbro 255. No issues.
Chris
At what fuel pressure would that be, just out of curiosity.
Old May 6, 2010 | 05:49 PM
phreaktor's Avatar
phreaktor
Design Engineer
Noob question- what is the fuel return used for?
Old May 6, 2010 | 06:16 PM
Chris@FsP's Avatar
Chris@FsP
It allows unused fuel during idle/cruising conditions to return back to the tank, instead of dead-heading at the fuel rail. It also allows you to use a fuel pressure regulator to regulate the desired base fuel pressure at idle and increase pressure at a 1:1 ratio with boost.
Old May 7, 2010 | 05:26 AM
DeatschWerks
43.5psi is what all of our flow rates are based on.
Old May 7, 2010 | 09:30 AM
brotus's Avatar
brotus
Here's a slightly off topic question. Would you be able to use a walbro fuel pump with the stock injectors/fuel system? I am considering removing my procharger and going back to stock.
Old May 7, 2010 | 12:35 PM
DeatschWerks
You should be okay if the FPR is in good order, however, if the FPR can't handle it you'll see a little higher pressure because of the pump and your gas mileage will suffer a bit.
pslamp32
Feb 8, 2017 09:07 AM
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
SpartanZ32
Oct 22, 2015 09:36 AM
Shane86
Sep 17, 2015 05:33 PM
