wideband bung welding
Old Jun 18, 2010 | 09:32 PM
kingjames23's Avatar
kingjames23
Default wideband bung welding
I have been reading about where most ppl have the mounting bung welded for the 02 sensor. Ive read pretty much pre-cat welding is where its been done for the 350z. Just wanna make sure this is fine.
Old Jun 19, 2010 | 05:02 AM
westpak's Avatar
westpak
SFZCC
well if you have cats then yes, because the wideband would be useless after the cat, if you have test pipes then it can be anywhere on the test pipe, without making much of a difference
Old Jun 19, 2010 | 12:33 PM
kingjames23
Thanks i still got the stock exhaust system and will prolly have it for a few months so yeh ill prolly have it welded before the cats
Old Jun 19, 2010 | 02:41 PM
GreenGoblin's Avatar
GreenGoblin
Your going to have to remove the cat to install the bung correctly, so why not pick up a set of test pipes and save the time of doing it later.
Old Jun 19, 2010 | 02:54 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Or...
He could purchase a set which already has extra bungs installed
Old Jun 19, 2010 | 02:59 PM
Hexxus's Avatar
Hexxus
This.
If you're not doing it yourself, you're going to spend the same amount on labor for the removal of the cats, prep work, welding, and to reinstall the cats as you will spend on just buying a set of test pipes with the bungs already pre-fixed, and you can do the cat/test pipe swap yourself.
Old Jun 19, 2010 | 07:33 PM
kingjames23
Originally Posted by Hexxus
This.
Best idea right there thanks!!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
FromGtoZ
Sep 20, 2015 03:41 PM
speedsniper
Sep 14, 2015 08:46 AM
