Accessory pulleys and FI
Old Jul 5, 2010 | 03:28 PM
jonnylaw's Avatar
jonnylaw
Default Accessory pulleys and FI
When I was NA I had installed a UR lightweight, stock size pulley set. When I went SC, the crank pulley was removed and so was the idler pulley as HKS has a specific replacement pulley. However, I believe the alternator lightweight pulley is still installed.
My question is are lightweight accessory pulleys a bad idea when FI, or does it not really matter?
I know a lightweight crank pulley is not recommended, but have not read any info on accessory pulleys and FI.
I am likely going to be changing crank pulleys soon, so if I need to address the alternator pulley I will. I have been having some issue with belts and tension (some slip/having to tighten belts), but am not sure if the UR alternator pulley would have any effect on this.
thanks.
Old Jul 5, 2010 | 03:51 PM
GreenGoblin's Avatar
GreenGoblin
I ran the UR alternator pulley and ATI and had no issues, but ended up taking it off so I could sell the UR set.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
