BigMo350z HR Greddy TT Build!
Old Jul 21, 2010 | 09:58 AM
  #41
BigMo350z's Avatar
BigMo350z
ODEHBOY^ Sounds good man! Let me know.
Has anyone done the Spec Stage 3 clutch on the Z yet on the HR specifically? Any reviews?
I recently ordered mine at Vivid racing (spoke with Sean stated it should be perfect for my setup I didn't feeling like running a 6-puck engagment is rough especially 1st from what I hear)... I've done some research and heard only good things so far they also stated clutch pedal feel should be close to stock and it can handle up to 495 ft tq.
Stage 3 Spec Clutch for 2007-2008 Nissan 350z
495ft lbs torque
Types of Driving:
Street, Drag, Pulling, Autocross
Features a carbon semi-metallic 6 puck sprung hub disc that has been the leading puck clutch in drivability, life and torque capacity. This unit is designed for street and race cars that require an aggressive but streetable engagement and high torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Also available in 3 puck configuration. Great for street, drag, road racing, pulling, rallye and drift.
•High clamp pressure plate
•Carbon-Graphite Friction Material
•High torque sprung hub and disc assembly
•Bearing and tool kit
Old Jul 25, 2010 | 10:12 PM
  #42
08NismoZ's Avatar
08NismoZ
Hey Mo i've been away from my350z for awhile but I just found your build page so i'm subscribing now haha
Old Jul 26, 2010 | 02:56 AM
  #43
MDHRZ's Avatar
MDHRZ
Updates?
Old Jul 26, 2010 | 05:05 AM
  #44
SV1098's Avatar
SV1098
495ft lbs torque
Types of Driving:
I'm searching for a clutch and flywheel combo as well. I was looking at Vivid's Stage clutches, but had no clue who made them. I've read so many issues with HR aftermarket clutches, that I want to buy the right one--the first time. Let us know how it works for you.
Old Jul 26, 2010 | 06:14 AM
  #45
MDHRZ's Avatar
MDHRZ
There really isn't any issues with the aftermarket HR clutches. The problem is the slave cylinder. The only company that has actually resolved this is ATS. ZSpeedPerformance has developed a work around until they come out with their new designed CSC. My SouthBend clutch and Flywheel work perfectly with a new CSC and the bearing sleeve.
Old Jul 26, 2010 | 08:08 AM
  #46
SV1098's Avatar
SV1098
I was leaning towards ATS for that reason, but it's big $$$!
Old Jul 26, 2010 | 10:11 AM
  #47
BigMo350z's Avatar
BigMo350z
Update- New Greddy Fmic should be arriving today sometime > Spec Clutch Stage 3 sometime this week as well as my Autometer Z gauges (3) + pod > 750cc Bosch injectors sometime this week :-)
Walbro is here as well as hks version III bov's
Old Jul 26, 2010 | 01:24 PM
  #48
binder's Avatar
binder
so is there a benefit to running a bov on each charge pipe over running a single bov off of the intercooler?
Old Jul 27, 2010 | 12:42 PM
  #49
BigMo350z's Avatar
BigMo350z
Thumbs up
Today, blow-off valves are a popular term describing pressure relief valves in automotive turbochargers whose inlets are located right between the turbo outlet and the intake throttle body. Their outlet is straight to atmosphere, and their actuation is intended to prevent turbo surge and boost damage upon rapid closure of the throttle under high power conditions.
Engine and Turbo Protection
•When used as prescribed, blow-off valves are designed to prevent compressor surge which is a condition where the rapidly spinning turbocharger which may be spinning at 100,000 RPM may suddenly decelerate to zero or even reverse itself when the accelerator is suddenly released at high engine power output. The after-turbo high pressure air is suddenly trapped after the turbo but before the throttle, reversing its own flow back through the turbo's spinning blades in the wrong direction. This can wreck a turbo unit or cause engine damage.
http://www.ehow.com/about_5332221_pu...off-valve.html
*It will be much safer according to this information.. With two bov's there is already 2 of everything with the HR motors*
Old Jul 27, 2010 | 12:53 PM
  #50
BigMo350z's Avatar
BigMo350z
Talking
Update - 7/27/2010
Special thanks to Dan at Speed Concepts for his great A +++ customer service. He has been on point since day 1. Quality parts and customer satisfaction 10/10 ! Packaging was extra enforced with security came in mint prestige condition! Also Vivid Racing for helping me choose the right clutch! Thanks again!
Old Jul 27, 2010 | 12:54 PM
  #51
thom000001's Avatar
thom000001
If its a common core IC, you could run 1 off IC. But if its a 2 core IC then you need 2.
Even if it is a common core IC, can't hurt anything to have one on each intake tube, and if thats where you locate them, it will look more balanced.
Tom
EDIT - After seeing pics, there really is no where to put a BOV on the IC anyway....so that kinda makes up your mind for you right there.
Old Jul 27, 2010 | 04:26 PM
  #52
SV1098's Avatar
SV1098
Like this?
Attached Thumbnails BigMo350z HR Greddy TT Build!-dsc00490.jpg   BigMo350z HR Greddy TT Build!-dsc00492.jpg
Old Jul 27, 2010 | 05:12 PM
  #53
BigMo350z's Avatar
BigMo350z
Looks Beautiful HR BUDDY! Thank GOD its almost done!
I'm planning to mount my bov's in the same area...
Old Jul 28, 2010 | 05:54 AM
  #54
SV1098's Avatar
SV1098
Thanks. We are ripping out the Greddy Ultimate and going with Osiris.
Old Jul 28, 2010 | 06:41 AM
  #55
MDHRZ's Avatar
MDHRZ
Old Jul 28, 2010 | 06:52 AM
  #56
SV1098's Avatar
SV1098
4 freakin days of tuninng the dam Ultimate! I WANTS ME CAR!
Old Jul 28, 2010 | 08:41 AM
  #57
supernadc2's Avatar
supernadc2
The closer it gets the harder it is. I had all the same excitement and finally the day came, and it rained!
Old Jul 28, 2010 | 08:42 AM
  #58
supernadc2's Avatar
supernadc2
Non the less the build looks great, enjoy man.
Old Jul 28, 2010 | 09:34 AM
  #59
SV1098's Avatar
SV1098
Thanks. Right now patience went right out the window!!
Old Jul 28, 2010 | 08:14 PM
  #60
nyZ_nick's Avatar
nyZ_nick
post some videos when youre done tuning
