misfires with PL kit
Old Aug 12, 2010 | 10:06 AM
str8dum1's Avatar
str8dum1
if it was flashing (that means gross misfire) , then you have a have a serious problem, either tune or ignition.
Old Aug 12, 2010 | 10:10 AM
Bigalow's Avatar
Bigalow
Originally Posted by djamps
If you've got the right plugs and gap (1 step colder), then it's usually tune related.
Do you notice your car driving less smooth than stock in part throttle?
I stock plugs in that case. as far as smoothness, the car feeling like its pumping when I'm driving but I think that's because my EVC VI is controlling it in 6 PSI - my low boost setting.
Old Aug 12, 2010 | 10:46 AM
Elperuano's Avatar
Elperuano
I've never had the ses light flash. it jus turned on solid n stayed that way...
Old Aug 12, 2010 | 05:10 PM
Bigalow's Avatar
Bigalow
Let me clarify my previous post. The car pumps sometimes when I up shift. This setup loves RPMs, and when I drive it like a DD, I conservatively shift around 2000RPM... which the car doesn't like.
Old Aug 12, 2010 | 06:30 PM
djamps's Avatar
djamps
Flashing SES light is really bad. That is worse than P0300 (your solid light). It means gross misfire. I've only seen that with either a bad coil pack, wiring issues, or a **** poor tune.
Get it fixed ASAP and lay low on the boost until then.
Old Aug 12, 2010 | 06:43 PM
str8dum1's Avatar
str8dum1
^^^ haha, did you just copy post #21
Old Aug 12, 2010 | 07:36 PM
djamps's Avatar
djamps
^ pretty much, it should be mentioned 5 more times LOL
Only time I have seen flashing SES the car was noticably running poorly (lost power) and turned out to be a bad coil pack. A buddy of mine also got it when his Vortech clogged his cats, and shortly after block grenaded. Just sayin'.
Old Aug 13, 2010 | 02:14 AM
Bigalow's Avatar
Bigalow
The flashing light is an issue but it's not the chief issue since it only happened 1% of the time. 99% of the time the SES is solid and annoying.
Thanks for the advise however, if it were to happen again then I'll have to stop what I'm doing and get it Function: Tuned right away. Anyways, I wouldn't be driving my Z anymore (except for the weekends) since I got the needed tires for my daily.
From what I gather from everyone's post, I either have a bad ignition system or my tune is shitty. I'll have to get it to FT for diagnosis. ...love you guys...
Old Aug 13, 2010 | 08:16 AM
Elperuano's Avatar
Elperuano
Hahaha
Old Sep 21, 2010 | 04:30 PM
Bigalow's Avatar
Bigalow
Hey guys as an update. I took the Z drifting this weekend and for some reason the SES turned off in the middle of the day. Ironically, I was driving the Z pretty hard and one of the instructors jumped in and drove the car even harder. I had appx 3 stalls throughout the day too. I don't get it - it's almost like the Z hates it when I have to daily it but doesn't ***** when I beat it up at the track.
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
