ceramic coating turbo headers +
Old Jan 29, 2011 | 07:23 PM
856_reilly's Avatar
856_reilly
Default ceramic coating turbo headers +
I was told to ceramic coat the hot side of the turbos and the down pipes... I was wondering how important this is or if it's a must.. Or am I just wasting money doing it. I am getting up there with the money and I still have alot to do. So how important is this?
Old Jan 29, 2011 | 08:10 PM
graffkid732's Avatar
graffkid732
I am stock block TT and everything came heat wrapped. But when I build, I will take the extra steps to protect and keep heat / temps down under the hood.
Old Jan 29, 2011 | 08:49 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
It will greatly reduce your under hood temps, but it is not a must do thing. However while everything is apart prior to the build is the ideal time to do it. It should only be a couple hundred bucks if I recall right, but I know how you feel near the end of your build you feel like you are getting couple hundred bucked to death.
Old Jan 30, 2011 | 05:24 AM
GreenGoblin's Avatar
GreenGoblin
I wish I would have done my manifolds, exhaust housings, and downpipes. I will do it next time the motor is out.
Old Jan 30, 2011 | 08:26 AM
Sylvan Lake V35
One of the upsides to rebuilding my car 3 times is doing all of the little things you wish you did the first time. I coated the hot sides, manis, downpipes, coolant hard lines, all of the air pipes around the turbos, the inside of the pipe that runs to the throttle body and the lower intake collector....I got a little carried away maybe OCD on my part
Old Jan 30, 2011 | 01:50 PM
856_reilly's Avatar
856_reilly
yea couple hundred bucks in me to death is right!!! I am agreeing with all of you it's just nickle and diming me.... now Hawk at J-tune said it's not that big of a deal if I don't do the housings. What do you guys think? And thanks for the help!!
Old Jan 30, 2011 | 02:25 PM
GreenGoblin
I would say if you can afford it, at bare min do the manifolds and exhaust housing. If you wanted to do anything else you could do that later on.
Old Jan 30, 2011 | 06:34 PM
856_reilly's Avatar
856_reilly
Gotcha thaxs brotha!!!
Old Mar 8, 2011 | 04:16 PM
Bigalow's Avatar
Bigalow
Impressive list. I JUST decided to do a ceramic coating. I think I'll just do the big 3 like Goblin mentioned: Exhaust housing, down pipes, and manifold.
Old Mar 8, 2011 | 05:55 PM
jruocco's Avatar
jruocco
I just got my parts back today. It wasn't too expensive, about ~350 for manifolds, exhaust housings and downpipes.
