Vortech running lean. help please
Old Aug 17, 2011 | 03:42 PM
rx7/350z's Avatar
rx7/350z
Default Vortech running lean. help please
Well after 3 years of smooth sailing my car seems to be running lean above 3.5k under wot boost. I recently had an issue with the passenger side cam sensor and that leads me to think I knocked something loose. The first replacement sensor was faulty and game me the p0340 again and also the code for cam over advanced(cant remember the code).
It looks like my ss box is altering the fuel , when I hear it click the a/f drops to around 10.9 and progressively leans out to around 13.5 at 5500. I didn't push it further than that. The vacuum lines looked ok. I also put power to the aux fuel pump and it started up.
I guess I'm going to have to go on a dyno to see if my wideband is accurate or hook up a wideband to see if the ss box is actually turning on the aux pump. Times like this I wish I bought a fuel pressure gauge.
Any ideas on what to check next? And please I don't need any comments telling me that I need a larger in tank pump and injectors.
Old Aug 17, 2011 | 05:56 PM
binder's Avatar
binder
you've mentioned what you need to check:
ss box really turning the pump on
a/f sensor bad
vac lines
so if the vac lines going to the FMU are working properly and the ecu is kicking on the pump at the correct boost then something else is going on. I wouldn't see this being related to the cam sensor. Did you take the plenum and stuff off when you changed the cam sensor? you could have an air leak somewhere.
Old Aug 17, 2011 | 07:40 PM
rx7/350z's Avatar
rx7/350z
Checked vaccum lines . Their good. I was really hoping that was it.
Old Aug 17, 2011 | 08:35 PM
ESP350Z's Avatar
ESP350Z
If it were me, id verify the a/f with another wideband sensor or a wideband at a dyno
Old Aug 17, 2011 | 09:17 PM
rx7/350z's Avatar
rx7/350z
Yea that's what I'm thinking. I just checked the inline fuse that goes to the aux pump with a multimeter and Im getting 12 volts under load.
Old Aug 17, 2011 | 11:16 PM
kajuraelai's Avatar
kajuraelai
whats your boost gauge read out when this happens?
Old Aug 18, 2011 | 01:14 PM
Sebascaris's Avatar
Sebascaris
check your aux fuel pump mine was unplugged and did the same over 5k rpm
Old Aug 19, 2011 | 09:27 PM
rx7/350z's Avatar
rx7/350z
I was reading that the ss box reads the cam sensors for rpm on the map. Now I'm wondering if the sensor might still be the problem. I'm going to put the old sensor back in and see what my a/f does.
Old Aug 20, 2011 | 05:35 AM
binder's Avatar
binder
that sounds like a good plan.
i know the ss box uses rpm but i'd have to look in the manual to find out which wire. I don't remember it being a cam wire for rpm but it doesn't sound completely unreasonable.
Old Aug 20, 2011 | 07:26 AM
jpc350's Avatar
jpc350
Believe cam 1 and cam 2 sensors are wired to the SS box.
Even though you have vac to the FMU it may be faulty...
Old Aug 20, 2011 | 01:18 PM
rx7/350z's Avatar
rx7/350z
Yes went on a dyno and was only getting 55 psi of fuel. Vac lines are good. I gave pressure to the fmu directly and fuel pressure came up ,but it but it only started to move after it got 6 psi. Looks like the fmu went bad .
Old Aug 20, 2011 | 02:18 PM
binder's Avatar
binder
In the settings of the ss box you can adjust when the FMU kicks on the pump. I think factory it's around 5psi before the aux pump kicks on so that's working normal.
Find out why there is no boost getting to the fmu. Something is wrong with that vac line if you can put pressure on it and it works. I'd swap the lines out.
Old Aug 20, 2011 | 04:06 PM
rx7/350z's Avatar
rx7/350z
The ss box is set how it came. It turns on the aux pump at -4 . I actually put power directly to the aux pump and it didn't help. My issue is definitely that the fmu is not operating. Either their is buildup in there or still a vaccum line issue
rx7/350z's Avatar
rx7/350z
Thanks for all the input guys.
Old Aug 20, 2011 | 08:05 PM
binder's Avatar
binder
vac line or maybe the diaphragm inside the fmu has dried out and cracked.
Old Aug 20, 2011 | 08:31 PM
rx7/350z's Avatar
rx7/350z
Luckily my friend has a new fmu that I'm going to try tomorrow
Old Aug 21, 2011 | 09:13 AM
jpc350's Avatar
jpc350
They have been known to go bad..
Old Aug 21, 2011 | 11:22 AM
rx7/350z's Avatar
rx7/350z
thats what it was. Ill post pictures of the fmu when i take it apart at work later
Old Aug 21, 2011 | 03:30 PM
binder's Avatar
binder
ya, that diaphragm kit from vortech isn't too expensive. I think like 12$ but you end up paying about the same in shipping because vortech hoses the customers on shipping.
I have the FMU with extra inline walbro from a vortech install i did on a friend's car a couple months ago. If you need one i can ask him if he would be willing to sell it. It also has the nice 6:1 rising rate ring in it instead of the factory 8:1. Keeps fuel pressures lower.....but now that i think about it if you're already tuned you would want to use your 8:1 ring so you don't have to have a retune.
Old Aug 21, 2011 | 03:33 PM
rx7/350z's Avatar
rx7/350z
Thanks but my friend had a new fmu that came with his kit he never used
