Little taste of the Greddy kit
Old Dec 16, 2003 | 05:26 PM
phunk's Avatar
phunk
CJ Motorsports
BTW I have a stock 350z exhaust for sale... that is unles Zig Zag wants it back yet?!?
Im moving next week... so call me up this weekend if you have the chance... check out the turbos and get this exhaust!
-Charles
Old Dec 16, 2003 | 06:36 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
the intercooler is soooooo nice! lets see the mounted intercooler pic on your car!
Old Dec 16, 2003 | 07:07 PM
JimRHIT's Avatar
JimRHIT
DAMN ... I am in Indy as well, but I am traveling to NY this weekend. I will have to come up some other time to check this out. Keep us posted on how it all comes together.
jim
Old Dec 16, 2003 | 07:14 PM
LaoSiFu's Avatar
LaoSiFu
DAMM I hate you LOL j/k.
Old Dec 16, 2003 | 07:26 PM
Fëanor's Avatar
Fëanor
The intercooler looks too tall for the opening in the Z's bumper. How does it get even airflow?
Old Dec 16, 2003 | 07:30 PM
Wicked4u2c's Avatar
Wicked4u2c
Do you have to take out your front bumper support?
phunk's Avatar
phunk
CJ Motorsports
The intercooler was on the car earlier today, but it is off again. I am working on a better power steering fluid cooler. I am not a fan of what Greddy gave me to replace the stock one with, and im not a big fan of the stock one either even tho im sure it is good enough for a daily driver.
The stock one is nicer then the Greddy replacement... and after putting it behind the intercooler it will loose some of its functionality.
For this reason I have already found the first upgrade I want to make to this kit (and i dont even have the turbos yet)... and that upgrade is going to be this power steering cooler upgrade kit. For those that road race or auto-x, it may be of advantage.
If you see that aluminum pipe that goes back and fourth to make 4 rows, thats the part I am speaking of. The stock one has 2 rows but has fins. Im gonna redo all that and use nicer lines that make the intercooler fit better then retaining these metal lines that are there.
Since my turbos will not be here until Friday.. I have until then to finish my power steering cooler system.
-Charles
Old Dec 16, 2003 | 10:39 PM
benzz280's Avatar
benzz280
Charles, glad that you are into the Z scene too! I have heard good things about you from apoji from IS300.net (you turbo'ed his SRT IS300)
Glad that there is an experienced tuner around here in the Midwest
Old Dec 16, 2003 | 10:59 PM
phunk's Avatar
phunk
CJ Motorsports
benzz280: thanks for the props! apoji's IS300 was a challange... ultimately we ended up running the SRT fuel system which was questionably lean... I tried my hand at the E-Manage in that car but couldnt seem to get the boards jumper settings to something that would run the car well... so I removed it. The owner later got some jumper settings from a IS300 tuner that they had figured out, and he reinstalled it himself and I guess it worked out for him, which is cool.... The car is supposed to come back to me in January I beleive for a compression lowering headgasket and some custom fuel system and tuning. I am looking forward to the headaches that car will bring me again!!! haha very easy car to work on mechanically but man the ECU in that car really kicks you in the ***! IS300 = Engine: easy, Electronics: WTF?!?
Old Dec 16, 2003 | 11:16 PM
phunk's Avatar
phunk
CJ Motorsports
Oops sorry guys missed the last 2 questions:
Feanor: The intercooler is definatly larger then the opening. However keep in mind, the intercooler has a very significant heat sink effect. Even if there was no airflow at all, it would still cool boosted air passing thru it until it was heat soaked. The air that does pass thru the opening in the bumper will directly cool where it hits, and of course from there you have the temperature transfer that will occur to eventually re-cool the entire intercooler.
This core is very large, and for the very low boost the kit comes set at, I dont think heat soaking the intercooler will be a problem at all.
Wicked4U2C: I regretfully must admit that yes, the bumper support beam is now removed. This core is far too large to fit in there and get along with the beam.
Now the thing is, its not uncommon for Greddy to release difference size IC core kits for the same car. I am hoping to see them release a half height kit for those that are not so hardcore... because there is plenty of room for an intercooler that would be a little smaller, as long as it had the 2 charge pipes collect before the inlet. If not, I am sure the day will come where a customer will want me or another shop to do a custom FMIC for the greddy twins that clears the bumper support, and hopefully then jigs can be made and a kit released to the public. Perhaps I should weld large beams to the intercooler to make it itself the support beam, haha.
I dont feel too bad tho... more often than not, anyone you see with an intercooler of this size has no bumper support beam. However the consumer must make the decision themselves under no other influence and readily accept the responibility of what they have installed on their car, and how it may effect the safety of the car. If it is a concern to you and you are a prospective customer of the Greddy TT system, I would highly recommend just having a trusted and experienced local shop build you a FMIC system that is slightly smaller. Unless you plan to really up the boost, this Type 23 Greddy core is just overkill (just the way i like it )
-Charles
Old Dec 17, 2003 | 02:38 PM
Zig Zag's Avatar
Zig Zag
-Charles
I am afraid to come to your shop bro.
You have something that I want,
.... I must .... fight.... the....urge.....
...I.... don't have....the strength.
I'll call you tomorrow, just tell me when is a good time, I will be there.
...and not jusy because you're holding my exhaust hostage.
Old Dec 17, 2003 | 05:48 PM
VR3's Avatar
VR3
phunk,
So when can we check out the car?? this weekend??
btw good luck with the install. I know you'll manage some big whp for us .
Old Dec 17, 2003 | 10:33 PM
phunk's Avatar
phunk
CJ Motorsports
this weekend may or may not be possible, depending on some other projects... we just finished doing a super crazy buildup on a honda civic and after breaking it in we have been taking the motor apart inspecting for proper break in with all the bearings and measuring everything up making sure its all in order.
i am hoping to have the Z running on saturday, the car will probably only run with the greddy kit how it comes for about 3 weeks... by then we will be upgrading the fuel and ignition systems and starting to turn up the boost and put together forced induction tuning kits for people.
I have made the decision to throw out the window all the super crazy ideas I had for the tuning and I am going to just install a FCON V Pro... im working on my pro tuner status with HKS, and should be setup today... Thursday. I will immediatly order the system and get it here so I can have it running in the car ASAP. The first few weeks in the new shop its nothing but playing with the Z and my Civic and one unfinished customers MR2 that is making the journey with us.
-Charles
Old Dec 17, 2003 | 11:41 PM
MR RIZK's Avatar
MR RIZK
If anyone can get their hands on the HKS tuning software in english to tune the FCON, It would be appreciated
PM me if you can help
Old Dec 17, 2003 | 11:53 PM
350ZMotorsports's Avatar
350ZMotorsports
The Greddy kit is a very nice kit. People should be very happy with it!
Old Dec 18, 2003 | 09:28 AM
phunk's Avatar
phunk
CJ Motorsports
Mr Rizk: You may have a lot of trouble getting that software. There are only 12 dealers in the USA that have it, and soon I will. If that software got out, whoever let it out is done as a Pro Dealer. I certainly wouldnt betray their trust and let it free. If you take your car to a pro dealer I am sure they could help you out.. but I dont know about anyone letting you have the software to take home.
Old Dec 18, 2003 | 12:31 PM
mpol99's Avatar
mpol99
I NEED to see your car when you are done & maybe get a ride in it
Old Dec 18, 2003 | 02:59 PM
  #38
MR RIZK's Avatar
MR RIZK
Phunk
I totally agree and would be happy to take it to a HKS Pro Dealer. The only issue is in Australia I do not beleive we have a Pro Delaer. There is a few guys that can tune the Japanese version of the software but they are not always in the country.
That is why I asked
Old Dec 18, 2003 | 04:48 PM
  #39
phunk's Avatar
phunk
CJ Motorsports
i understand... i did not know you where in Australia i wish i could help ya.
Old Dec 18, 2003 | 07:23 PM
  #40
Judge's Avatar
Judge
Phunk,
I'm in Bourbonnais... about 90min. from Aurora. Where in Aurora are you located? Do you have a shop setup for engine upgrades? If so, I would like to see it and maybe have you do my install when the time comes.
Thanks
