Oil/water feed/drain on Twin Turbo HR.
Old Oct 5, 2011 | 02:15 PM
C-unit's Avatar
C-unit
Default Oil/water feed/drain on Twin Turbo HR.
I am going TT on my VQ35HR and I am in the process of fabricating the oil drain/feed and water feed/drain on the turbo.
Does anyone have a pic on how a GTM/Greddy TT kit on doing their feeds/drain? I just want to get some reference so I know I am on the right track. i did some search on pics but pretty much everything is so tightly packed and all I can see is the oil drain are tap to the pan.
I appreciated for any pointers!
Old Oct 5, 2011 | 03:35 PM
str8dum1's Avatar
str8dum1
tapping the pan above the oil line is the correct way. otherwise use an oil pan spacer and return there. not as good, but thats how those kits do it.
Old Oct 6, 2011 | 01:34 AM
C-unit's Avatar
C-unit
Just did more research:
I found the instruction of the Greddy TT kit and you get the oil feeds from the pressure sensor port. So the oil issue is solved!
However, Greddy kit aren't watercooled so I am not exactly sure if I should tap the heater hose. Anyone can snap a pic on their TT set up on where the water line goes?
Old Oct 6, 2011 | 04:17 AM
rh_334's Avatar
rh_334
GTM inserts a tee fitting on the heater hoses, on the passenger side it replaces a plastic joiner and on the drivers side i can't remember if i had to cut the hose in half or if there was a joiner. Look up a parts list for the GTM kit you should see it, basically same thing DE APS kits use except they use 2 of them.
edit: you can see them in this pic
Old Oct 6, 2011 | 05:04 AM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
http://www.airpowersystems.com/350z/...stallation.htm
This should also help:
http://www.airpowersystems.com/350z/...tall/guide.htm
Old Oct 6, 2011 | 05:39 AM
ace32x's Avatar
ace32x
On either side of the block there are 2 bolts screwed in that lead directly to coolant passages, for my build were just running cooling lines directly into these holes and then taping the coolant pipe that goes from head to head on the back of the engine and running the return back on either side there, alot better than how gtm and greddy have theyre water lines set up.
And if your interested i have a twin plate os giken HR clutch for sale and am fairly close to you. would cover shipping or if u wanted to pick it up id meet you half way https://my350z.com/forum/drivetrain/...to-700-tq.html
Old Oct 6, 2011 | 08:30 AM
C-unit's Avatar
C-unit
Thanks alot for the help!!
I already have a OS twin for HR..exact same set up as yours!!! lol GLWS man
SharX59
Sep 27, 2015 09:23 AM
