nitrous kit
Old Jan 4, 2012 | 09:54 PM
HieuVo350z's Avatar
HieuVo350z
Default nitrous kit
pm me what you have kits,and accessories :cool
Old Jan 5, 2012 | 07:26 AM
justboughtaz's Avatar
justboughtaz
Default Zex Wet Kit 82220
I have this kit, its brand new I don't need it, part number is 82220
Old Jan 7, 2012 | 10:36 PM
rookie_z's Avatar
rookie_z
i have a NOS kit with 2 10lb bottles electric bottle opener. both bottles have aftermarket high flow valves. i have the NOZZLES which are rare to find they slip over the fuel injectors so it is easy to hide from the cops. i have 2 14' hoses and 1 1' hose 4an size the two bottles have pressure release and down tubes. i also have the window switch and wide open throttle switch which only allows the nitrouse to activate under a certain set rpm range and only when the throttle is wide open also has connection for fuel pressure sensor so if u run out of fuel the system will shut off im looking for 1,500 plus s&h and the bottles alone are worth over 1,000
Old Jan 8, 2012 | 05:01 AM
droe2001's Avatar
droe2001
taken down
Old Jan 8, 2012 | 05:27 AM
droe2001's Avatar
droe2001
taken down
EnjukuRacing
Sep 30, 2015 06:55 AM
