Trouble with turbo G35, AFR in 9’s, hesitation, P0340/5
Old Mar 6, 2012 | 09:46 AM
  #61
thatv35guy's Avatar
thatv35guy
Originally Posted by bigcloud
Ummmm. Isn't that like really bad!!!! At least your timing chain didn't come off. Is it a simple fix?
Yeah, doesn’t seem like a real simple fix… the front timing cover has to come off and the book’s calling for 11 hours to replace the timing chain, I figure it should be just below that… not sure though, still trying to figure out my next step…
Old Mar 6, 2012 | 10:06 AM
  #62
RandomHer0's Avatar
RandomHer0
Wow, never heard of that happening on a VQ
Old Mar 6, 2012 | 12:45 PM
  #63
ace32x's Avatar
ace32x
pull the core support out and do it in the car
Old Mar 7, 2012 | 08:51 AM
  #64
str8dum1's Avatar
str8dum1
thats probably how the book calls for it to be done in 11 hours
Old Mar 7, 2012 | 10:48 AM
  #65
ace32x's Avatar
ace32x
seems a bit long
Old Mar 7, 2012 | 02:03 PM
  #66
Alpha @ IP's Avatar
Alpha @ IP
So, I’ve been having some very troubling issues with my G35 recently, here are some of the symptoms I’m experiencing right now:
• The AFR is sitting in the 9’s very consistently at nearly any amount of throttle (occasionally it’ll dip into the 10’s or slight higher but for the most part it’s in the 9’s)
• The car’s struggling to go past 2500 RPM
• Lots of hesitation above 2000 rpm
• Last time I checked I’m getting 2 CEL’s: P0340 AND P0345 (I believe they’re related to the camshaft position sensors, I’ve replaced the sensors from both banks with the sensors from my brother’s 350Z but I’m getting the same CEL’s still)
I’m not sure what to do at this point, does it seem like the car could be in limp mode? Does limp mode cause an extremely rich AFR? If so could that have cause the plugs to foul? Any other suggestions?
I'm getting into this a little late. But. Why not have Jason or Saad check the car out?
Old Mar 7, 2012 | 02:23 PM
  #67
str8dum1's Avatar
str8dum1
I know it was more than 2 posts above your response, so its understandable why you didnt see it.
So, got a bit of an update… ProEFI had a chance to take a look at the car and from what I’ve gathered so far the timing chain jumped a tooth and it’s off now… that’s why the car’s stuck in limp mode.
Old Mar 7, 2012 | 02:32 PM
  #68
Alpha @ IP's Avatar
Alpha @ IP
You're right Good luck. Sucks to hear.
Zume
Mar 18, 2007 06:06 AM
dynamic6er
Mid-Atlantic
Dec 5, 2005 02:09 PM
zimbo
Sep 8, 2004 03:58 PM
uncg35c
Apr 29, 2003 12:18 PM
