Another Vortech Build
So I just ordered my kit from assultech today. Dan was very helpful. already cant wait to get it on the car. Here are the parts for my build so far:
Vortech V-3 tuner non rev-up satin kit 650cc Bosch injectors Walbro 255 fuel pump NKG spark plugs Weapon R oil catch can Uprev GT MAF sensor I need help deciding which pulley to go with from 928 motorsports. I believe that i need the 6 rib 17mm pulley. I cant decide between the 3.15 or the 3.00 pulley. Any suggestions? I want to balance power and reliability like most people. I am going to Hill's Garage for the install. They are a little pricey but the quality is second to none. they are the only shop that i trust with my car. Frank, the owner, recommended that i get a stage 0 fuel return system and the Vortech S Trim Performance Impeller. I do believe that these parts would be best for performance wise but idk if im ready for these yet. Currently on my car i have an AP single exhaust, Stillen Y-pipe, Fast intention resonated test pipes, skunk2 plenum spacer, and Uprev dyno tuned to 264.8rwhp/255retq. Im estimating that with the kit i should be around 370-390whp. |
In for results.. :)
Many say start with the 3.12 pulley. I did the opposite and started with stock 3.33 but upgrade my impeller to the SI trim. Click on my link for more info.
Goodluck and can't wait to see results! |
Originally Posted by unvmyg35
(Post 9660730)
no reason not to start right with the 2.87. doesnt make sense to buy a pulley you are going to use for a couple weeks then swap.
Originally Posted by str8dum1
(Post 9660939)
Originally Posted by Boosted Performance
(Post 9660960)
Not to mention the cost for tuning the car twice in a short period of time.
I get 9.5 lb with 3.13 I have been boosted for 40k miles 415 rwhp
Fuel return is highly recommended for F/I. They make for a more precise tune and equalize the flow between banks and cylinders. Can you get by with no fuel return? Sure (at your power level)... but if you have the cash and like to do things correctly then get a basic return setup.
Originally Posted by MUZZY
(Post 9661085)
Originally Posted by djamps
(Post 9661091)
UPDATE:
I am purchasing the 928 motorsports vortech S trim performance impeller tomorrow and getting the CJM stage 0 fuel return system next week. still have not decided what size pulley to use yet, either the vortech 3.12 or the 928M 3.00. |
Originally Posted by lillong1991
(Post 9661481)
UPDATE:
I am purchasing the 928 motorsports vortech S trim performance impeller tomorrow and getting the CJM stage 0 fuel return system next week. still have not decided what size pulley to use yet, either the vortech 3.12 or the 928M 3.00. I believe the 928M impeller info starts on page 2 in my thread here: https://my350z.com/forum/forced-indu...-v3-setup.html |
(Post 9661110)
I completely agree with you. Im most likly gonna order the cjm stage 0 return system tonight. This way i dont have to completely change the fueling maps if i get a smaller pulley. Also im thinking of buying the 928 impeller too
Originally Posted by Threads
(Post 9661771)
If your blower(more specifically the blower's volute) isn't a S-Trim, the impeller will not be a correct fit.
(Post 9661812)
My blower is a Vortech Tuner Kit, 03-06 350Z/G35 (Non Revup) V3 SQ SCi-Trim & Charge Cooler, Satin - $3,750.00
(Post 9661817)
Yeah, that's the same exact blower I ordered from assaulttech. You will definitely want to read my thread before purchasing to see what I had to go through to get the 928m impeller to work properly with my setup.
(Post 9661867)
O wow, i had that same misconception that you had at first about the whole S-trim thingy. all those letter can get confusing. question for you, is the 928M pulleys direct fitments on our kits?
Upon installation, it might be handy to have some sort of heat source to heat the pulley up prior to installation. They fit very tight onto it's mounting point. As well, I had to trim my pulley's key because the pulley is slimmer (doesn't have the excess on it like the Vortech pulleys do. |
(Post 9661878)
Yes. I run the 2.62 pulley on my setup. Just make sure you get the right rib/size for our applications.
Everything has been ordered and am currently awaiting shipment. 928M 3.00 pulley. still debating on weather or not to get the GTM pulley kit mod. any suggestions and now for some pictures of the car/ parts:
Rear shot of the car http://i1087.photobucket.com/albums/...991/350zAP.jpg Exhaust pic of the car http://i1087.photobucket.com/albums/...91/photo13.jpg Weapon R oil catch tank from B2autodesings http://i1087.photobucket.com/albums/...91/photo23.jpg |
