T-Trim Boost Help! lost a 100whp literally
Old Apr 11, 2012 | 05:23 PM
IngsVortech350z's Avatar
IngsVortech350z
Default T-Trim Boost Help! lost a 100whp literally
So i now have the Vortech v2 t trim before i had the si trim on the 2.87 pulley laying down a good 430whp no that i have put the t trim on im making 300whp how the heck did i loose all that power when all i changed was the blower
mods
ipp 8.8:1 block
stock heads
Brian crower stage 2 cams
ID725cc injectors
Kinetix Race Manifold
Pmas
aam fuel rails
aam return
walbro 255pump
Uprev tune
2.87 pulley 32 cog and whatever the stock cog on the blower
Mishimoto FMIC 30x12x3.5"
berk test pipes
greddy exhuast
1 step colder plug
Old Apr 11, 2012 | 05:31 PM
05Z33's Avatar
05Z33
Are you making boost? Check all your couplers, you may have a loose one.
Old Apr 11, 2012 | 05:37 PM
IngsVortech350z
yes it hits 7.81psi i holds it till redline
Old Apr 11, 2012 | 05:43 PM
05Z33's Avatar
05Z33
You should be making alot more boost than that, like 14-15psi. Double check your couplers. I bet that is the issue. Also it could be belt slip.
Old Apr 11, 2012 | 05:50 PM
IngsVortech350z
i have the extra pulleys for the tension and the couplers are all tight with new clamps, do you think the cogs need to be changed?
Old Apr 11, 2012 | 06:11 PM
OldManZ350's Avatar
OldManZ350
NO!
You have a Boost Leak, or Belt Slip........
Old Apr 11, 2012 | 06:24 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
not sure if you should own such a setup with comments like "hits 7.81psi and holds it to redline"
find your leak/slip, fix it.
Old Apr 11, 2012 | 06:27 PM
Nexx's Avatar
Nexx
lol for real.
Old Apr 11, 2012 | 06:29 PM
IngsVortech350z
hey i was going off the dyno sheet for psi.. im not that big of an ******* about it
Old Apr 11, 2012 | 07:13 PM
OldManZ350's Avatar
OldManZ350
can you post the dyno sheet?
Old Apr 11, 2012 | 07:45 PM
05Z33's Avatar
05Z33
Make sure you still have all your teeth left on the cog belt as well. As OldManZ350 said post up a pic of your dyno graph as well if you can.
Old Apr 11, 2012 | 08:03 PM
unvmyg35's Avatar
unvmyg35
Originally Posted by OldManZ350
NO!
^Agree check your set-up throughly! I have the SI v2 with a stock 3.33 pulley and im making 11psi.
Like Ice Cube says, "Check yourself before you wreck yourself!!"
Old Apr 12, 2012 | 06:35 AM
djamps's Avatar
djamps
belt slip
Old Apr 12, 2012 | 06:39 AM
NZMOWND's Avatar
NZMOWND
no clue about FI but i bet these guys know there **** so im gonna say belt slip to sound smart
Old Apr 12, 2012 | 07:37 AM
tonyzS/C03's Avatar
tonyzS/C03
but for real OP you def have belt slip or leak someplace. how much boost were you making before?
Old Apr 12, 2012 | 01:09 PM
binder's Avatar
binder
i concur....super chargers don't "hold boost". Max boost is at max rpm. It should always be climbing and linear.
Old Apr 12, 2012 | 11:27 PM
IngsVortech350z
Ya ill get the sheet up on here it's weird as **** I've never seen it do this before it hits good boost to like 4k then flatline even the tuner was a little baffled..
Old Apr 13, 2012 | 07:55 AM
binder's Avatar
binder
I wouldn't be baffled. It's not holding pressure somewhere or the belt is slipping. Check belt first the look for boost leaks second. Should be a simple fix once you find it.
Old Apr 13, 2012 | 08:42 AM
str8dum1's Avatar
str8dum1
FWIW, did you ever push on the valve in the BPV? if so, that ruins it and it could easily not be holding boost. Has to be sent back to vortech for rebuild.
Sounds like nothing was touched though besides just charger swap. If your idle vacuum hasnt changed, then the leak must be between the tb and the supercharger outlet.
Old Apr 13, 2012 | 11:19 AM
IngsVortech350z
Ya I took the valve over to Vortech and dropped it off for a rebuild they said if that doesn't fix it to maybe try the mondo valve and ya the vacuum is exactly the same so I'll recheck the belt
