Help!!!! Low Boost Problems.
Old May 31, 2012 | 08:22 PM
binder's Avatar
binder
i use solid copper gaskets now with copper gasket spray on all of them. My other gaskets didn't hold up too well.
I have 2 years of hard use with snow and ice on my 2nd generation design with no cracks. This last design looks even better so there shouldn't be any cracking issues anymore.
Old Jun 1, 2012 | 05:57 AM
350zion's Avatar
350zion
Professional
Jeff, shoot me some info on ur gaskets... I need to replace mine n now is a good time since everything is outta the car....
Ray.
Old Jun 2, 2012 | 09:17 PM
binder's Avatar
binder
Ray.
i'll send you an email. summit racing carries them now.
Old Jun 9, 2012 | 09:12 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Update:
1.5" Crack on top of WG, welded it up. Put a boxed in gusset.
Flex Pipe Failure:
Blew out the side, smoking hot exhaust on the transmission
New Berk Gaskets are much more robust.
Ghetto Patch to keep the trans safe on the ride home.
Old Jun 10, 2012 | 06:28 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Solutions.
Sasha hit me up last night and offered to fix it no worries, however shipping to near Russia is much more expensive than just buying the flex pipe from vibrant and rewelding it in. All that being said. I decided to order a bunch or 4" piping and fabricate a new exhaust that will eventually go onto my 6766 turbo, even if it is overkill for now. I am also ordering a 10" piece of flexible fiberglass heat shield to slip over the flex pipe and provide a safety net should it blow again.
Old Jun 10, 2012 | 10:41 AM
binder's Avatar
binder
bummer. The new revisions on the kit will keep this from happening. My flex pipe is quite a big larger in diameter than the one you have which makes me think it can be flexed without damage a bit more. Mine is still good after 2 years.
Looks like you were a good test subject Don. sorry the crap hit the fan for you though.
Let me know if you are willing to part with that 6262 for me to do some testing to see if i would like a smaller turbo. I'm a broke grad student so i can't buy new turbos just to experiment.
Old Jun 10, 2012 | 02:13 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Id gladly part with the 6262 if I had something to swap to instead. I have been looking at this 6466 and the 6766 for sometime now.
I went ahead and got a 6" flex pipe which I will also have ceramic coated and wrapped. This should double up on the protection.
Old Jun 10, 2012 | 02:36 PM
konrad's Avatar
konrad
You guys should swap turbos 6765 for 6262 win win LOL
Old Jun 10, 2012 | 07:20 PM
binder's Avatar
binder
ah, i misread. I thought you said you HAD the 6766 turbo.
unless i don't like the results then i have to buy another turbo! I'm just concerned about my ported heads flowing more than that 62 hotside can handle. The 65 hotside would be better but it's hard to find used turbos (that are worth the money the owner wants)
Old Jun 10, 2012 | 08:09 PM
konrad's Avatar
konrad
^ jeff check this out
http://usedturbos.net/Catalog/index....d=19&Itemid=53
Old Jun 10, 2012 | 09:00 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Jeff Id happily switch with ya straight up, But I can't do much more right now than that.
Old Jun 11, 2012 | 02:16 PM
binder's Avatar
binder
ya i know. I just got overly excited because i read it wrong and thought you had the 6766. I was thinking the 6262 was going to just sit in the garage doing nothing.
Old Jun 11, 2012 | 02:20 PM
binder's Avatar
binder
this is awesome. thanks!
Old Jun 11, 2012 | 06:08 PM
konrad's Avatar
konrad
no problem, they just recently got a lot of precission turbos and they update the site every time they get something new and its always almost half price from retail, I just dont know if they give any kind of warranty
350Z_Al
Oct 29, 2020 07:44 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
