TwinTurbo help.
Old Jul 29, 2012 | 12:48 PM
350zpearl's Avatar
350zpearl
Default TwinTurbo help.
i have an 03 350z with greddy TT, with haltech, new clutch..
question:
from take off.., clutch, 1stgear, and gas my rpm drops like its gonna stall unless i give more gas or ride the clutch. i feel like every gears have a pause or it lags. when its on neutral its steady rpm. Is this normal, or what am i missing?
thanks,
jeff
Old Jul 29, 2012 | 01:05 PM
jerryd87's Avatar
jerryd87
traction control off?
Old Jul 29, 2012 | 01:07 PM
350zpearl's Avatar
350zpearl
are you talking about the VDC? its always ON, could that be it?
Old Jul 29, 2012 | 01:26 PM
jerryd87's Avatar
jerryd87
guarantee thats it turn it off, mine attempts to do something similar just cruising because of my tires size's if i forget at wot car usually just power through it but im probably making a good deal more power then you, or my system could just be fubar *shrug* but its widely known you can run it on a FI car because you will kill your spark because you will see some wheel slip. depending on tire sizes that could compound the problem.
but yah turn it off, its crap on a stock car, its triple crap on a FI car
first thing i do every time i fire up the car before even moving is hit the button.
Old Jul 30, 2012 | 08:28 AM
350zpearl's Avatar
350zpearl
tried it and it somewhat makes a difference when vdc is off. however from 1st gear, the rpm hesitates and then goes up to normal.. not really sure whats up..
Old Jul 31, 2012 | 08:33 AM
350zpearl's Avatar
350zpearl
shop thinks i need a bigger flywheel, could this be it?
Old Jul 31, 2012 | 08:37 AM
ace32x's Avatar
ace32x
Never heard of that
Old Jul 31, 2012 | 08:59 AM
0jiggy0's Avatar
0jiggy0
Maybe they mean your flywheel is too light causing the rpms to drop too fast between gears.
Old Jul 31, 2012 | 09:08 AM
350zpearl's Avatar
350zpearl
oops yeah i think thats it, i bought the exedy clutch kit from here, which one you'd recommend for heavy clutch?
Old Jul 31, 2012 | 10:45 AM
thisishk350's Avatar
thisishk350
If you've got a light weight flywheel switch back to something heavier.. They're good for NA not for boost
Old Jul 31, 2012 | 11:37 AM
accordfreak's Avatar
accordfreak
are you using the internal map sensor?
if so, it lags the throttle response for a split second due to the long vacuum line. Either find a better vacuum source or switch to an external sensor.
Old Jul 31, 2012 | 07:30 PM
jerryd87's Avatar
jerryd87
doubtful, i have the fidenza/jwt flywheel with a southbend ceramic with ss pressure plate. as extreme as you can from a single for this platform and is more aggressive then 90% of the clutchs made for this platform with 0 issue. light weight flywheel and boost problems need a driver mod not a part mod.
op do you have a video?
Old Jul 31, 2012 | 08:08 PM
binder's Avatar
binder
how many miles on the clutch?
The clutch on this car sucks pretty bad and unless you have an RJM adjustable bracket you have to give it quite a bit of gas to take off without stalling. I had to take off at 2500 rpms with my os giken until I got the new adjustable bracket and now I can take off without touching the gas.
Old Jul 31, 2012 | 08:50 PM
350zpearl's Avatar
350zpearl
id say under 200 miles...
i will try to take a video and post it here... thanks.
Old Aug 1, 2012 | 11:09 AM
binder's Avatar
binder
Are you sure it's not slipping since it's new?
The hard to take off sounds like a normal thing for our cars but the mid gear shifts could be due to the new found harder bite on this clutch or if it's slipping when you shift because it isn't broken in fully yet.
Old Aug 1, 2012 | 12:06 PM
djamps's Avatar
djamps
I've ran both heavy and light flywheels without issues. It's all in the tune...
Old Aug 1, 2012 | 12:17 PM
graffkid732's Avatar
graffkid732
I was going to say, I had a light flywheel and had 0 issues with it.
Old Aug 1, 2012 | 12:23 PM
bgant3's Avatar
bgant3
nevermind
Old Aug 19, 2012 | 10:09 AM
350zpearl's Avatar
350zpearl
UPDATE: Omg... i just needed to switch from 91 octane to 94, and it runs like a champ. arrrrrr!
Old Aug 19, 2012 | 10:31 PM
AnnLindel's Avatar
AnnLindel
AbrasiveRaysive
Sep 20, 2021 02:29 PM
_koubie_
Sep 20, 2015 06:34 PM
