FS: HKS F-Con V Pro
Old Dec 3, 2012 | 04:58 PM
TheSteve's Avatar
TheSteve
Default HKS F-Con V Pro
Switched my Z to a different EMS and now have an HKS F-Con V Pro in perfect working order for sale. Comes with ECU, harnesses, AFR monitor, Fcon Navigator, all sensors, original packaging.
ECU is tuned to run an 06 Z on a Turbonetics single turbo kit with 600cc injectors. I highly recommend you get this retuned immediately and I do NOT stand behind or warranty the current tune when used with your car. Due to mileage I recommend replacing the wideband before running this kit.
On to the pics:
Overview of everything
The F Con V itself. The ECU was double-sided-taped to the AF-Knock Amp computer. I did not want to risk scratching the ECU trying to get the tape all the way off
AF Knock Amp
Displays for Knock Amp and Navigator. Unfortunately I didn't get any pics of them powered. No dead pixels or other issues.
Now onto the less interesting stuff.
HKS Wideband O2 sensor with harness
External MAP sensor
IAT sensor
Harness for MAP and IAT
Harness for AFKnock Amp
Main harness
Closeup of Main harness's connection to Fcon V
You'll notice a lot of bullet connectors and a couple of cut wires. The HKS units use the bullet connectors to make it easier to add modules in later; the AF Knock unit plugs right into these. The cut wires were all O2 sensor related- power, ground, signal, etc. These are detailed in the various manuals and are nothing out of the ordinary for connecting O2 sensors.
Boxes for F-Con V and Navigator
Manuals for Navigator and mounting brackets for AF knock amp display
Receipt snippets showing some of the HKS parts
I'm looking for $800 shipped. This is in perfect working order and you should expect no issues with anything unless mentioned above. I am not extremely firm on the price. Not wanting to separate these unless you make a good offer.
Please let me know if you have any questions whatsoever, I'd like to see this sold!
Old Dec 6, 2012 | 09:08 PM
TheSteve's Avatar
TheSteve
Lowered the price a bit to try and have this gone soon
Old Dec 28, 2012 | 11:52 AM
TheSteve's Avatar
TheSteve
Bump. Feel free to make offers.
Old Jan 2, 2013 | 08:29 AM
TheSteve's Avatar
TheSteve
Sold, thanks!
KOF
Tuning
Sep 30, 2015 04:09 AM
