FS: Defi Gauges (awesome look) and AEM AF UEGO
Old Dec 6, 2012 | 12:40 PM
ConradoR's Avatar
ConradoR
Default Defi Gauges (awesome look) and AEM AF UEGO
SOLD I’m moving overseas for my company for the next two years, so I have removed my SC after 6 months of use, and I'm parting out the car then selling it (SC is already sold).
DEFI BOOST GAUGE
DEFI GAS/OIL PRESSURE GAUGE
I couldn’t be happier with the gauge setup that I ended up with! The amber matches the Nissan/Infiniti Amber interior perfectly. Later I found out that DEFI makes OEM tachs in Japan, so the near perfect match made a lot more sense. Anyways, if you want a clean yet aggressive look, these are the way to go! These were only made for a few years, back in the early 2000’s and I was able to find a set. This is a unique opportunity!
Pressure one could be used for oil or gas pressure, its the same sensor. I used it for my oil pressure since the g35s dont come with it, but these originally came from a 350z that used it for the gas pressure.
They come with the wires to hook it up, fitted for a coupe which I will assume that would be long enough for a 350z! All you are missing is the boost line, which is a windshield fluid line and it’s 5-10 bucks tops.
Selling Both for $300 shipped! SOLD (Will not split the pair)
AEM UEGO AF
AEM Uego Air/Fuel Ratio. Comes with sensor. Also comes with extra white faceplate and silver bezel. The AEM Uego is known as the best, most reliable AF in the market. It also doesn’t require resetting it like some other brands do if the car battery is disconnected.
$150 shipped SOLD
Video I made:
BTW: I'm not so active at my350, but if you need validity, I can pm you my info from G35driver, I'm under the same username/password there with 1500+ posts and 15+ itrades
Thanks :biggthumpup:
SOLD
Old Jan 16, 2013 | 04:12 AM
ConradoR's Avatar
ConradoR
SOLD.
Thanks!
bcoffee20
Nov 19, 2015 06:39 PM
350Shadow
Sep 22, 2015 08:30 AM
Calinismo350z
Sep 14, 2015 04:04 PM
