Built S&R single turbo DE Kit (now VSR Motorsports)
Old Jan 30, 2013 | 06:01 AM
GAMERMODZoCOM's Avatar
GAMERMODZoCOM
While the cams should give you a little less lag, there are other variables to it. One of these variables was that you went from 10.3:1 compression down to 9:1 which will increase the spool time. I don't know any math to estimate that to determine how much. By having a properly tuned VE map before and after plus the compressor map for the turbo would be the only true way to determine what the difference would be (with all other things being equal ie. wastegate spring, target boost level, etc.).
I am not sure what spring you are running in your wastegate but it will also affect spool up.
There are other things that can affect spool but based on the information provided, those are the only two that stick out to me. Remember, any time you do things to create more power, you typically sacrifice something. In your case, it may some spool time.
Old Jan 30, 2013 | 06:30 AM
GAMERMODZoCOM
Originally Posted by jerryd87
yah but im running even lower compression then you thats why im amazed, im running 8.0:1 compression and 6765(well was) with .96 a/r housing and was seeing 15 psi boost about 4k and 26 psi at 5k according to data logs vs your 14.7 with tiny turbo, tiny exhuast housing and higher compression lol like i said i knew cams would right shift it but damn thats alot i would expect your spool to be left shifted at least another 500 rpm mayby even 1k with such a small turbo and housing.
The size of the turbo doesn't really matter. Your motor is producing a different CFM at different RPM's, on a compressor map that is (more than likely) completely different than his compressor map. This does not mean one is better fit than the other however. While you spool quicker, his turbo could be running 15lbs in a more effecient island while you are spooling more effeciently but less effecient at target boost.
I am not saying that is fact, I am just giving an example of how two different builds, with two different turbos could act/spool differently not even including the tons of other variables that help/hinder spool time.
Old Jan 30, 2013 | 08:36 AM
jerryd87's Avatar
jerryd87
It is true that a lot of variables come into play however generally speaking a larger turbo usually takes longer to spool up, and mine is quite a bit bigger then his not to mention a much much larger a/r on mine. Taking into account both our static compression ratios and cams our dynamic compression ratios are very similar. Those two things are going to make the biggest differences and my guess is there's a lot left to be had in timing but not 100% sure
Old Jan 30, 2013 | 10:15 AM
GAMERMODZoCOM
The general concept most people understand is that if you go with a larger turbo then you will not spool up as quickly. Just because this is what most people have heard/read doesn't make it "always" true.
If you go and spec a few turbo's for your car with accurate information, you will get an idea of what I am talking about when you chart the compressor map for your target boost level. Compressor maps vary A LOT from turbo to turbo. Finding a turbo that has the fastest spool AND the best effeciency is nearly impossible. Your usually sacrificing a little of one for another.
I personally charted at least 20 different turbos for our application and ended up having to get the guy from Honeywell (Garrett) who specs turbos for sponsored race cars to help us. What ended up being the most ideal was a GTX4294R. That turbo on our configuration will spool up to 15lbs by 3400RPM however, we are in the 60% effeciency island up to about 4000RPM then fall back in to th 60% effeciency islands by about 7000RPM.
As far as timing goes, tuners are not typically overly conservative at RPM levels nearly half of redline therefore I would find it extremely hard to believe his timing is far from MBT from 1000 - 4000 rpms... Especially since I am familiar with Brian's tuning on Osirus.
Other contributing factors making a difference in spool is the intercooler size, the piping length, piping diameter, exhaust restrictions, wastegate spring pressure, wastegate size, cam profiles, air-fuel ratio's and too many others to list.
There are many differences between engine builds, turbo kits and supporting mods that when people start comparing one build to another for the sake of "how they think it SHOULD perform", I just shake my head. There are just too many variables to make assumptions on what it "should" have made for power, how the torq curve "should" have looked, etc.
Old Jan 30, 2013 | 11:54 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by Boosted Performance
Nice try, and please do some research on the dyno first:
http://www.cadillacforums.com/forums...j660s-cts.html
This means that this particular car would make about 510whp on a DJ, and THAT means that I am still right. Remember, I have customers making low to mid 600's on DJ's, using pump gas with the T4 .81 a/r turbine housings (18-20psi). These are also simple short block builds, stock heads, cams and intake manifolds. Last time I checked "you boys" had a strung out kit on race gas, and a crap load of boost to get over 600whp (not sure about head work/cams on that engine)
A true comparison would be same day (hour) runs on the same dyno during the same conditions. Or even better, run them at the track. I don't know why it is so difficult for you to understand EBP numbers, and simple fluid dynamics. If EBP is twice the boost pressure...the turbine is TOO SMALL. At 16 PSI we were getting about 30psi of EBP (exhaust back pressure) before the turbine inlet with a T4 .81 a/r 6765. Just think what it would be like on a T3 turbine...again, read up on it, it will help (I hope) you understand the issue at hand just a bit more. Also, while reading, take note to what goes on with IAT's when the turbine is too small for the engine. I have dyno plots to prove this, with EBP printouts so let me know if you want them posted. At the same time I can post a couple of links on the topic, so that others can learn something you have such a hard time with.
Just thougth I correct you on that. I will not be posting anything else in this thread. So if you have any constructive input, or better yet, actual valid data (comparable) to back your statement up, feel free to PM me.
OP, sorry for the OT stuff. As long as you are happy with the way the kit is performing...that is really the most important thing here.
Nice try at cherry picking one source from a Google search that was reposted in a couple different forums. That thread doesn't discuss any experiences with the dyno at S&R/VSR either. I Googled "dynomite dyno vs dynojet" and found several links with a WIDE VARIETY of opinions and experiences on the dynomite dyno compared to other dynos (no shock there). Some said they read high and some said they read low. I found no solid consensus that the dynomite reads higher than other dyno brands. Hell, look at the huge variation in numbers amongst DJ dynos, and they are supposedly the industry standard. Within a few minutes of reading, I found numerous posts with experiences where a dynomite read lower than a DJ or another dyno. Here are a few examples:
http://ls1tech.com/forums/dynamomete...mite-dyno.html
http://forums.240sxone.com/showthread.php?t=27959
http://www.modularfords.com/threads/...ll-humble-you!
This thread had people posting differing experiences for high and low readings...
http://forums.evolutionm.net/evo-dyn...tang-dyno.html
So you have not provided any conclusive evidence to prove that S&R/VSR's dyno reads high. And I can only recall one or two of your DE customers on this forum who dyno'ed over 600whp with your kit, and they used 67mm turbos.
Bottom line: The OP's dyno numbers still refute prior defamatory statements you made in your negative marketing campaign to promote your own turbo kit over the top mount ST kits. Of course, trap speeds at the track are the best way to validate dyno claims. Regardless, it's cool to see another top mount kit making respectable pump gas numbers ...especially since one vendor on this forum has been asserting that such numbers are dubious and impossible to achieve without a T4 housing. Congrats to S&R/VSR and the OP.
Old Jan 30, 2013 | 12:15 PM
GAMERMODZoCOM
We have had our car on multiple dynos S&R's Dynomite, a brand new (at the time) Dynojet, Top Speeds dyno which I think was a dynojet and was fairly new and old dynojet at a shop I will not mention. The ONLY one of these 4 that was off more than a couple HP was the OLD dynojet. Not going to mention who had it but man, it was nearly 30whp higher than the rest.
I am not saying all dyno's are equal, I am just pointing out that S&R's dynomite and "new" dynojets read within a coupe hp of each other in our experience.
We had our car at 648WHP with 14PSI on pump.
Old Feb 6, 2013 | 11:23 AM
FastWhiteZ's Avatar
FastWhiteZ
I'm still running the original 7lb wastegate spring. We're planing on replacing it with a 12lb spring soon.
Old Feb 6, 2013 | 11:29 AM
GAMERMODZoCOM
Yeah, going to the 12lb spring should help your spool. Since that is close to your target of 14.7, make sure your boost controller is configured properly so you don't get boost spikes far above your target.
Old Feb 6, 2013 | 07:26 PM
FastWhiteZ's Avatar
FastWhiteZ
I don't know if these will post. I'm not too familiar with posting videos. If they work these are a few videos of the car on the dyno.
https://www.facebook.com/photo.php?v=599240133426470
Old Feb 6, 2013 | 08:24 PM
bmyles's Avatar
bmyles
Nope. Easier to upload to Youtube or Photobucket.
Old Feb 6, 2013 | 08:53 PM
FastWhiteZ's Avatar
FastWhiteZ
Hope this one works:
Old Feb 6, 2013 | 08:55 PM
FastWhiteZ's Avatar
FastWhiteZ
One more:
Old Feb 7, 2013 | 09:39 AM
binder's Avatar
binder
There are actually mid 600 on the 6266 on pump gas. All of the ones with the smaller 6262 are stuck under mid 500's. What's the difference? the size of the exhaust housing. Makes a huge difference in flow.
Nice numbers though! I'm sure it would matter what gear the car was in unless this is a load based dyno. If it's a non-load based and it was used in a low gear it would cause that power shift like that. I guess it could be the backpressure on the turbine side that causes a little later spool.
