350z driving me crazy please help.
Old Jul 4, 2013 | 01:25 AM
carlbaker34's Avatar
carlbaker34
Car idles high. Cel is multiple random miss fires. The car honestly sounds like its cammed or like the sti . No smoke anything. Lost a lot of power .
Old Jul 4, 2013 | 04:24 AM
amr_electron's Avatar
amr_electron
Did you perform a cylinder power balance test ?, You can use cipher to do it easily .
Old Jul 4, 2013 | 04:49 PM
carlbaker34
Do not have cipher unfortunately..
Old Jul 9, 2013 | 05:15 AM
carlbaker34
Motor went today leaky injector...
Old Jul 9, 2013 | 07:59 AM
350z006's Avatar
350z006
Went? Did you mean it died or blew?
Old Jul 11, 2013 | 01:31 AM
carlbaker34
Blew threw a rod through the oil pan.
Old Jul 11, 2013 | 07:10 AM
iideadeyeii's Avatar
iideadeyeii
In for the pics
Old Jul 12, 2013 | 08:08 AM
binder's Avatar
binder
So I got this rattling noise today an it sounds like vvt but would that cause a big power lose? How hard is it to clean ? Thanks again!!
Looking back the noise wasn't cam noise. As stated in the thread it's only on start up.
Originally Posted by binder
It sounds like something else is going on.
So I doubt it was phantom knock or a bad knock sensor. Your car was telling you something is wrong and you kept driving it. It obviously was real knock that caused destruction. I said to check the injectors and harness. Not trying to be mean but this is why you just take it to someone who is skilled.
Old Jul 13, 2013 | 01:33 AM
carlbaker34
Changed the vvt an rattle was gone. An knock sensor was also a issue had a bad harness. Solved the low input ks code. An you mention electrical. An check the harness not the injectors. An driving it wise I started it an took it around the block a morning a week. Fuel in oil was the problem.
Old Jul 13, 2013 | 06:07 AM
binder's Avatar
binder
ya, that tends to be a big problem!
etkms
Jun 19, 2022 06:30 PM
SonnyWu
Nov 24, 2015 08:19 PM
_koubie_
Sep 20, 2015 06:34 PM
