Tuning Greddy e-manage (password?)
Old Jan 26, 2004 | 11:04 AM
g356gear's Avatar
g356gear
Default Tuning Greddy e-manage (password?)
To anyone who is tuning the pre-programmed e-manage for the 350Z tt kit......how are you doing it? I was under the impression that there was a password on the unit to keep people out of it and messing with the supplied base maps.
Old Jan 26, 2004 | 12:39 PM
Yancy's Avatar
Yancy
profec e-01 boost controller - designed by Greddy as a combination boost-controller, data display/logger, and e-manage programmer.
Old Jan 26, 2004 | 01:20 PM
g356gear's Avatar
g356gear
I am refering to the pre-programmed e-manage that comes with the kit. I need to know how to access it if I don't have an e-o1 to make the changes.
Old Jan 26, 2004 | 02:13 PM
jak's Avatar
jak
What yancy is saying is you can't get into the pre-programmed e-manage so people are using the profec e-01 boost controller along with e-manage and new maps.
Jeff
Old Jan 27, 2004 | 05:47 AM
g356gear's Avatar
g356gear
I suppose the other option would be to buy a new e-manage and taylor it to you're own preference and engine set-up. The amounts of timing that are taken out seem to be fairly close between the different kits -2 degrees low down, -4 degrees mid range, and -6 to-8 degrees up top. The rest would just be A/F tuning.
Old Jan 27, 2004 | 05:51 AM
g356gear's Avatar
g356gear
Jeff
Are they using the e-01 to access the locked e-manage that comes with the kit or are they using the e-01 with a brand new e-manage to tune the kit?
Old Jan 27, 2004 | 06:34 AM
ZMike's Avatar
ZMike
Yes, basically you cannot touch Greddy's tune. I don't think they will EVER give the password. I think you need to erase the E-Manage somehow and start from scratch.
As for timing, i was under the assumption that Greddy only gives you the main and injector harness. i've never seen a picture of the ignition harness included. so i imagine it's running on stock timing.
Old Jan 27, 2004 | 07:03 AM
12SecZ's Avatar
12SecZ
So there isn't like a "GOD MODE" or anything, that sucks.
Someone will hack it eventually.
Old Jan 27, 2004 | 07:46 AM
etx's Avatar
etx
"i've never seen a picture of the ignition harness included. so i imagine it's running on stock timing."
Connecting the ignition to the emanage would be simple. I assume the VQ uses waste spark so it's probably got 3 grounds to control the coil packs. Cut the ground between the ecu and the coil packs and connect them to the ignition signal input / outout of the emanage. done.
Old Jan 27, 2004 | 08:19 AM
g356gear's Avatar
g356gear
Then a new e-manage box would be the way to go and replace the one that comes with the kit. For a couple hundred bucks it would seem to be the most logical choice.Then laptop tune it to where you need it.
Old Jan 27, 2004 | 08:32 AM
MrBonus's Avatar
MrBonus
Crap. So there's no way to reset the EPROM (I'm assuming that's what it uses for memory) if you were to buy an E-Manage from someone?
I'm asking because I have an Evo and was considering buying an E-Manage off of a member here from their TT kit. I already have a Profec B - Spec II so I don't want to buy an E0-1.
Old Jan 27, 2004 | 11:45 AM
spazpilot's Avatar
spazpilot
you can reset the emanage, even the ones that come with the kits. On the eo-1 profec just hit initialize and that will erase all programming. With the software there is an option under one of the tabs if I remember correctly.
Old Jan 27, 2004 | 11:57 AM
phunk's Avatar
phunk
CJ Motorsports
spazpilot speaks the truth. you can basically "reformat" the e-manage and use it however you please. You can do it thru the E-O1 or thru the laptop software.
Old Jan 28, 2004 | 06:07 AM
g356gear's Avatar
g356gear
Then what is the purpose of the password that blocks changes?
Old Jan 28, 2004 | 07:59 AM
spazpilot's Avatar
spazpilot
For Greddy to get there turbo carb approve there can not be a way to manipulate the ecu, so they block the emanage with a password.
Old Jan 28, 2004 | 08:15 AM
ZMike's Avatar
ZMike
is Greddy TT CARB approved? I didn't think it could be. The Greddy Emanage itself is not CARB approved. it says so right in the instruction manual.
Old Jan 28, 2004 | 10:02 AM
g356gear's Avatar
g356gear
If you reset it does that take the password lock with it? I wonder if you can still access and view the programming without being able to make changes? The reason I ask is I am curious if you could copy the file into the laptop and then re-load it into a new e-manage without a password so they you could tune all you needed. At the least I would hope you could access the files and copy or print out the curves so you could re-input then to a new e-manage.
Old Jan 29, 2004 | 04:13 AM
spazpilot's Avatar
spazpilot
If you reset it it will take the lock off. It will be ALLLLLLLL gone. I tried to view it with the eo-1 and it won't let you at all. It first asks for the password. So you can't even view it to re input the values.
Old Jan 29, 2004 | 05:54 AM
g356gear's Avatar
g356gear
So we are SURE there is a total reset function for a locked e-manage. Has anyone done this themselves yet? This is a main issue for me as to whether I go with this kit or not.
Old Jan 29, 2004 | 06:39 AM
etx's Avatar
etx
Yeah, The initialize function will return the e-manage to stock config as if you purchased the e-manage by itself. I'm sure GReddy locked the emanage so that people cannot see thier config and tool around with it. After you initialize it you can set your own password, or not use a password at all.
