My greddy twin turbo set up
Old Nov 12, 2013 | 09:28 AM
z33_cliff's Avatar
z33_cliff
Default My greddy twin turbo set up
Well coming from several force induction cars, Even though I told myself i was only gonna keep my Z stock with the exception of wheels, lowering springs and minor cosmetic mods. I found a deal on a partial greddy kit that I couldn't pass up. The kit consisted of just the manifolds, turbos, some oil lines, oil pan, and few charge pipes. So I had to track down everything else like BOV, wastegates, intercooler, fab the piping, injectors, etc
Luckily I have a close friend with a garage to drop out my engine
Pulling in to get started
wiring out, almost time for the drop out
unbolted down under and ready to set the engine/ trans on jack stands
Shes out!!!
putting on all the kit.... later realized I had the charge pipes coming out of the turbo outlet backwards
Dropping the car back on the engine and setting up the intercooler and piping
DONE!!!! at least till my exhaust comes in this week and install that, injectors and clutch and tune next week
Old Nov 12, 2013 | 10:53 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
interesting. glad to see you were able to salvage the kit.
do you think merging the turbo charge pipes so kuch sooner will have any negative effects? I belive the greddy kit uses a single core intercoolee but not sure if the air from each turbo combines until the outlet of the ic.
Old Nov 12, 2013 | 11:17 AM
taywan's Avatar
taywan
Cool. like to see results on power. what other mods on it? And mileage??
Old Nov 12, 2013 | 06:16 PM
bealljk's Avatar
bealljk
I would call it as a single core extruded tube...
and yes both ducts merge post-intercooler - I can only assume this was done to keep internal pressure losses to a minimum
The OP's looks also like a single core extruded tube style...I think there will have a little higher loss due to that junction - is it the end of the world?? I doubt it, the fabbed-up junction looks (relatively) smooth - just my 2cents...
Old Nov 13, 2013 | 02:47 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
yeah not saying it is a huge red flag, just something to think about.
love the wheels btw, i need to pick a set up one day.
Old Nov 13, 2013 | 03:40 PM
z33_cliff's Avatar
z33_cliff
That was a worry for my with joining the two turbo into a single inlet/ out let intercooler vs the dual inlet single outlet greddy provides but after checking out the power enterprise kit and playing around with some piping we got the merge to be pretty smooth... could I make more power with better piping and parts? I'm most positive I could but I have probably 1/4 of what a greddy kit cost in my set up and thats including an uprev license.... The way I look at it, it works, it makes a lot more power than it did, sounds great, i'm only one in town with a tt z33 and mainly it puts a huge smile on my face everytime I drive it
Old Nov 14, 2013 | 01:44 PM
J rad's Avatar
J rad
Ah coollllllll fabing! In for more pictures.
Old Nov 14, 2013 | 04:44 PM
bealljk's Avatar
bealljk
theoretical...how you have it fab'd and the single in single out intercooler is going to increase your pressure loss due to a slightly less efficient merge point and intercool setup.
But dont sweat it - keep moving forward with your build -
Old Nov 14, 2013 | 06:11 PM
Resmarted's Avatar
Resmarted
Don't worry about your piping stuff. Mine's retarded in comparison to even that. You get pressure loss and more lag with more piping/retarded piping but you can still make plenty of power.
Old Nov 26, 2013 | 12:01 PM
Wbruce03's Avatar
Wbruce03
I am fixing to pick up a very similar kit as well. I need to pick up BOV, intercooler kit, downpipes, and intakes and intake piping. What all did you go for on BOV and fmic?
Old Nov 27, 2013 | 01:02 PM
suprasam's Avatar
suprasam
Tial is a good one to go with. Most name brands will have enough spring pressure to work with what boost these turbos make on the vq
Old Nov 28, 2013 | 06:10 PM
buffhulk's Avatar
buffhulk
hey looks great i love the greddy twin kit except i was racing a newer m3 today and even though i won it was knocking hard i heard alot of clack clack clack clack from the motor i got off it quick and drove normal a bit....got back on it and it felt great whatever by what size are your rpf1 broski they look NASTY
Old Dec 8, 2013 | 05:15 PM
z33_cliff's Avatar
z33_cliff
I went the cheap route with my intercooler set up, I ordered a bunch of steel U bends and J bends in 2" and 3" to build the piping, went that way cause I don't have a tig let alone never used one or welded aluminum so I went this way and ordered the biggest and thickest FMIC on ebay I could find that would fit behind my stock bumper. I contemplated going with the greddy FMIC but 2g's for that kit is way out of my budget plus I'm not looking to make tons of power, if I can get 350hp cool if I can reach 400+ even cooler. Only goal for this set up is to make at least 100 extra hp and not blow up.
Old Dec 8, 2013 | 06:20 PM
bealljk's Avatar
bealljk
you'll see 400 just fine, stay under a 450 on an OEM block. You're setup looks good. There are some minor inefficiencies with the intercooler but you're not looking to set records - a good tune and you're gonna be rolling!
Can I convince you to add an oil cooler?
Old Dec 9, 2013 | 05:26 AM
buffhulk's Avatar
buffhulk
do the oil cooler I listened to bealljk .....and whats your wheel setup?
Old Dec 11, 2013 | 03:26 PM
z33_cliff's Avatar
z33_cliff
I've entertained the idea of an oil cooler, Its on the list but for now I'm looking to get the clutch in and the car to the tuner for the time being.
19x10 +22 all around 15mm spacers front 20mm rear
Old Dec 14, 2013 | 03:33 PM
Resmarted's Avatar
Resmarted
You can do an oil cooler for under $200
There really is no excuse not to run one.
Old Dec 14, 2013 | 03:35 PM
NA&CH's Avatar
NA&CH
I need to do this.
Love the 19x10 enkeis.
Chris
Old Dec 15, 2013 | 09:42 AM
bchalks's Avatar
bchalks
I didnt know they made those wheels in 19"? Are they new?
Old Dec 16, 2013 | 12:56 PM
buffhulk's Avatar
buffhulk
hey whats the progress have you tuned yet or any updates
