***Updates*** For Drags Jan 2014
Old Dec 14, 2013 | 04:58 PM
OldManZ350's Avatar
OldManZ350
Default ***Updates*** For Drags Jan 2014
1. New M/T ET Drag 3055S 28x10.5x15, had to modify the inside of the wheel well to fit. One inch taller and one inch wider that my last set of ET Streets. Should keep me off the rev limiter thru the traps and pick up some mph too.
2. Line Locks
3. DriveShaft Loop required by NHRA ( was already installed for last time out)
Attached Thumbnails ***Updates*** For Drags Jan 2014-dsc00094.jpg   ***Updates*** For Drags Jan 2014-dsc00091.jpg   ***Updates*** For Drags Jan 2014-dsc00100.jpg   ***Updates*** For Drags Jan 2014-dsc00103.jpg   ***Updates*** For Drags Jan 2014-dsc00106.jpg
Old Dec 14, 2013 | 05:16 PM
meanz's Avatar
meanz
Looks like a bad as$ set up! I would love some rears like that.
Old Dec 15, 2013 | 05:49 AM
Conway_160's Avatar
Conway_160
I don't think traction will be an issue any more...
Old Dec 15, 2013 | 11:25 AM
Classy's Avatar
Classy
Looks like it is still missing 2 cylinders
Old Dec 15, 2013 | 05:14 PM
Quamen's Avatar
Quamen
Looking good! I loved my 28" tires, although with my setup I wish I had gone even taller. Should hook very nicely and pull hard!
Old Dec 17, 2013 | 10:09 AM
str8dum1's Avatar
str8dum1
you should post all your drag threads in the drag racing forum to get interest going there.
Who recommended going with the stiff sidewall tire?
Old Dec 17, 2013 | 11:25 AM
OldManZ350's Avatar
OldManZ350
Micky Thompson did.
They call it a Stiff Wall, but it's still a Wrinnle Wall, just made for cars over 3000 lbs.
Old Dec 17, 2013 | 12:32 PM
djamps's Avatar
djamps
Are the locks to save your rear brakes, or are you having a hard time keeping it still? I always get the stink eye from the pit crew for burning out too long even without locks LOL. I'm sure you've heard it (maybe already do it) but avoid 1st gear... your tires will never become hot enough no matter how long you peg the redline, will try to hop around, and generally be harder to keep still than a good 2nd gear dump at 4-5krpm.
Also, where did you get the loop made?
Old Dec 17, 2013 | 12:51 PM
OldManZ350's Avatar
OldManZ350
Line Lock are for burnouts… I always do a 2nd gear burnout. I have a 6 speed and can't hold the car with the brake.
Dynosty $ made the DS Loop, but it's just 1/4 x 2 mild steel flat bar. you could do it cheaper…… just by a Lakewood Loop ($30) and modify it to fit.
Old Dec 17, 2013 | 07:38 PM
Resmarted's Avatar
Resmarted
Looks good.
Any info on that driveshaft?
Sports Aluminum?
Old Dec 17, 2013 | 08:31 PM
OldManZ350's Avatar
OldManZ350
http://www.driveshaftspecialist.com/
Old Dec 17, 2013 | 09:04 PM
Resmarted's Avatar
Resmarted
Originally Posted by OldManZ350
Right on. I think this is exactly what my setup needs.
Old Dec 18, 2013 | 08:22 AM
str8dum1's Avatar
str8dum1
ya i was just curious bc you dont see them getting used often. Supras and other similar weight cars use the 10.5 standard tire.
I never bothered with anything smaller than 28" race tires. I could easily roll thru the 1/8th in 3rd. 26" street tires I had to shift. The little extra height should really help any traction issues as well as stay in gear longer. Win win!
Micky Thompson did.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
