Dyno results-----Supercharged
Old Aug 30, 2014 | 05:01 PM
t0rqu3's Avatar
t0rqu3
Originally Posted by bealljk
Am I reading your dyno sheet correctly seeing that you made your 390whp at 13psi??
Yes you read it right; any input you have is appreciated! Thanks I'm advance
Old Aug 30, 2014 | 05:04 PM
t0rqu3's Avatar
t0rqu3
Originally Posted by cashmoney03
That looks like a very fun car to drive. 400hp is more than enough to get you in trouble. I once thought I wanted a 600hp street car. Going sideways at 70 as the boost hit is nerve racking.
It is fun having 400whp, it's useable and does not make the car go side ways at 70mph.....that would be crazy!!!!
Hats off to fellow drivers who handle cars with such brute power!
Old Aug 30, 2014 | 05:08 PM
taywan's Avatar
taywan
Originally Posted by OldManZ350
Do people even Read the Title or Subject of the Thread anymore, before making an uneducated statement?
Nope..
Old Aug 30, 2014 | 05:10 PM
t0rqu3's Avatar
t0rqu3
Originally Posted by pss350z
Thanks for sharing OP. And, 50% more power over stock Z of whatever engine is huge. Lol at the douches that come on here drunk or not and talk stupid ****.
Wish there were some good supercharger options for us HR owners. Stillen apparently sucks and GetTheMoney is (or was if they're still operating) horrible as far as customer service goes.
You are welcome..... It's not just the power I enjoy it's the total experience which is exciting ....hearing it spool and then the BOV .....it feels great cause it is something you customized.
Old Aug 30, 2014 | 05:12 PM
t0rqu3's Avatar
t0rqu3
Originally Posted by WTFMike
I said that once...
Lol .....I guess it's a matter of time before I get greedy for more power
Old Aug 30, 2014 | 05:25 PM
Conway_160's Avatar
Conway_160
Is this on a very conservative tune or was this all you could get out of it due to knock? I get mine tuned on Wednesday and will also be pushing 12psi but with a procharger.
Old Aug 30, 2014 | 05:36 PM
turboed350z's Avatar
turboed350z
Oppsy ****ing dooo so it's smaller supercharger vs a small turbo. Size still ****in matter
Old Aug 30, 2014 | 06:44 PM
bealljk's Avatar
bealljk
Well, you may want to get a second opinion on your tune...
I've trended boost psi to whp for a little while now and you are well 'below the curve'
at 13psi up in colorado I made 455whp with a modified procharger on a built block. Using the trendline formula 13psi averages 488whp - so you are 100whp lower than the average 350z owner making 13psi.
The trend formula (upper right hand corner) is whp is equal to 249 base whp plus 19whp for every 1 psi of boost...
Old Aug 30, 2014 | 07:35 PM
turboed350z
Wouldnr depends on the size of the supercharger? I know xoming from the mustang worl, the root style twin screw kenbell 2.2l makes a hella more more power at the same psi than it does in a smaller size one.
Old Aug 30, 2014 | 08:30 PM
t0rqu3's Avatar
t0rqu3
I honestly don't know ....here is what I know.
The car first made 4psi and 280whp due to UR small crank pulley and 440cc injec. Then going back to stock crank it made 10psi and made 370WHp. Moore automotive said upgrade fuel injec so we can give more fuel and create more power and safer power. After going with 1000cc injec the boost went to 13psi but they could only extract 20whp!!!
4psi to 10psi and increase of 6psi gave 110whp but going from 10psi to 13.4psi and increase of 3psi and more fuel should have made more power!!!
How can one tell the engine is knocking??
Old Aug 30, 2014 | 08:31 PM
t0rqu3's Avatar
t0rqu3
Thanks for sharing....very good info!!
Old Aug 30, 2014 | 09:17 PM
OldManZ350's Avatar
OldManZ350
t0rqu3,
Give us the specs on your Vortech Setup.
What is your Rev Limiter set at?
What ECU or Piggyback?
Serp pulley size? 3.33, 3.12, 2.87 ext
Cog pulley setup (32/28 is Stock for a DE)
And supporting modifications, like headers, exhaust, intake, ext....
Thanks,
TimRod
Old Aug 30, 2014 | 09:35 PM
t0rqu3's Avatar
t0rqu3
t0rqu3,
Thanks,
TimRod
Sure.
Rev limit 7400rpm
UPREV TUNE
Serp 2.87
Cog 34/28
Kinetix v2, racing headers, berk hfc, hks dual exhaust, jwt flywheel and clutch.
I hope I answered them correctly !
Old Aug 30, 2014 | 11:22 PM
OldManZ350's Avatar
OldManZ350
Thanks.....
Motor Built? IF so, specs
I forgot to ask about your fuel system, other than the 1000cc injectors.
What are you using for an Intercooler? The one that come with the Vortech Kit?
Old Aug 31, 2014 | 03:12 AM
Jaxter's Avatar
Jaxter
Sure.
Rev limit 7400rpm
UPREV TUNE
Serp 2.87
Cog 34/28
Something is way off. That pulley combination should be spinning your Vortech around 65K. Most cars pushing a Vortech that hard are making 17+ psi and 550 hp. Are you positive those are the pulleys installed? If so, I would get a second opinion pretty quick. Can you take another picture of your dyno sheet that shows the rpms along the bottom?
Old Aug 31, 2014 | 04:07 AM
OldManZ350's Avatar
OldManZ350
Ya, I wanted to get all the info I could before telling t0ru3 something is off with he's numbers or info and/or not setup right. i.e. fuel system, intercooler, pulleys, belt slip?
This is to help you get your car setup correct, nothing else. I can do this thru a PM if you would like to keep it private....
TimRod
Old Aug 31, 2014 | 06:30 AM
Jaxter's Avatar
Jaxter
TimRod
I have never seen belt slip that could build linear boost all the way to redline. Would it have to be slipping at all rpms? Could there be a boost leak? Damaged impeller? Incorrect info? Were the runs being cut short?
I think a lot of pictures of the setup would help out. Count the cogs, measure the Serp pulley, measure the crank pulley, are there any check engine lights, get a second opinion on the tune.
If there is a boost leak. Definitely don't fix it and drive it without a retune.
Old Aug 31, 2014 | 07:45 AM
  #38
OldManZ350's Avatar
OldManZ350
Ya sure. To many unknowns for me, need to be cleared up.....
Old Aug 31, 2014 | 07:47 AM
  #39
t0rqu3's Avatar
t0rqu3
Thanks.....
Stock motor and inter cooler is just basic correct.....for fuel it's a 255 in the tank without fmu and return system
Old Aug 31, 2014 | 07:51 AM
  #40
t0rqu3's Avatar
t0rqu3
Jaxter and OldmanZ350 -----greatly appreciate the input ....I recounted the pulley last night but will do it again in the morning.
