Need some turbo help
Old Mar 27, 2015 | 07:51 PM
hotrodtrevor's Avatar
hotrodtrevor
Originally Posted by 350zjason350z
Boost controller, Ecu or tuning software ....
It comes with a flash cord and then I can just use oasis or where that program is right?
Old Mar 29, 2015 | 05:04 PM
Escobar's Avatar
Escobar
yea you buy a cord with a license on it from UpRev and then you can flash it. You will need a tuner to make the maps. Or you can go piggy back or full standalone like Haltech. You dont need a boost controller. Thats 400-500 you can save.
Old Mar 29, 2015 | 06:04 PM
jerryd87's Avatar
jerryd87
not even close on the suspension, CHEAP "cambergang hella drop" coilovers alone are 1200. For making power might as well stay stock for what good that will do you, what about bushings? better lsd(not needed but helps a ton)? figure closer to 5-6k for a decent suspension. any intention of track? if not then brakes wont matter too much if only highway or drag but if for the track you need those too. guages alone for MECHANICAL guages will run you 300-400 forget about wiring. plugs? gaskets that may be needed? if the kit is 5500 its missing **** or is used and likely needs to be looked over. if your doing all the work yourself figure 10-15k and thats using used parts and catching some deals, 20k if everything new and doing twins(with the singles out there the whole twin thing is a waste really......) built engine for more power?
Originally Posted by hotrodtrevor
I found a gtm kit for 5500 mean suspension for 1200 I have rims and all the gauges and wireing is less then 300. I am very capable of doing all the work myself. I have access to a lift a cherry picker and engine stand. Along with a full toolbox. I posted on the very first post the link to the turbo kit I am looking at. I just need someone to help let me know if it's good for daily and if theirs anything else I need to get other then gauges
bcoffee20
Nov 19, 2015 06:39 PM
