Greddy MAP sensor for tuning??
Old Feb 9, 2004 | 09:48 AM
g356gear's Avatar
g356gear
Default Greddy MAP sensor for tuning??
What are the opinions on using the optional Greddy MAP sensor for tuning instead of the stock MAF readings with the Greddy TT kit?? Thanks.
Old Feb 9, 2004 | 12:24 PM
etx's Avatar
etx
The MAF cannot see boost, only flow. I will probably pickup a map sensor for the emanage once I get into the higher boost levels. Or I may go standalone, in which case I would not need it.
Old Feb 9, 2004 | 02:34 PM
g356gear's Avatar
g356gear
I was thinking of using the MAP for tuning entirely instead of even using the MAF signals to the e-manage. Even at 6-7 pounds I think it is better to program the tables based upon boost vs throttle position instead of rpm's vs throttle position. Feedback?
Old Feb 9, 2004 | 03:25 PM
etx's Avatar
etx
I strongly agree with you. If you have the profec e-01 you can get the optional harness that will supply the e-manage with the map signal from the sensor on the e-01. I'll be doing that asap.
sales@czp
Sep 23, 2019 03:30 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
