t32gzzzz
I'm pretty sure T32gzz has not changed any internal engine parts, but he did install an OS Geiken (sp?) clutch and lightweight flywheel I believe to handle all of the power and torque his bad *** Z is putting to the ground. If you do a search, you'll find that he has explained his set up somewhere on this forum. Changed out the e-manage, different fuel pump or auxilory pump, TS reflash, great tuning of the kit for his car. I'll leave the rest to Tim.
If you want to run high boost you will need to build your block up with Closed desk sleves, forged pistsons and rods, and nice berrings. I would also recommend a set of ARP head studs while ya got the heads off.
