Engine Management Solution, I found one.
Old Mar 19, 2004 | 08:41 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally posted by phunk
im not... stock injectors are in the car. once we install the FCON we will put in 720cc or larger injectors.
So if the eManage isn't controlling timing, that what the heck is it's purpose, other than controlling 440cc injectors that the car doesnt even need until you get to really hi boost levels.
Old Mar 19, 2004 | 09:08 PM
azrael's Avatar
azrael
azrael: i definatly understand what you are saying. I am also glad that you understand HKS' decision to keep it real.
However, keep in mind, there are other devices that could be included for end user adjustments. This way if small changes are made down the road, they could accomodate them. But for any major tuning, a Pro-Dealer is required.
It sounds like you got your end taken care of, but this is a very good option for someone who just wants their car done and doesnt want to have constantly tinker and tune it.
I am expected to catch a lot of flak (sp?) for offering this as a solution. I know everyone would like to be able to tune their car. The fact remains that 90% of people in this industry are not qualified nor have the proper equiptment to tune their car properly. The people that this rule applies to, who have the awareness that its a lot easier said than done (properly), have no need to have any adjustment control at all. Its just like buying a pretuned JWT ECU for your fully built twin turbo 300ZX... works like a charm and you never need to screw with it... for as much HP as you could ever want.
My goal is to provide a tuned fuel system capable of 800rwhp that would require no later adjustments unless there were major changes to the engines volumetric efficiency.
-Charles
I understand 100%. In fact, I am really happy you're offering a solution like this. Just like you said, 90% of people in the industry have NO CLUE what they are doing. Having the right equipment AND know-how is priceless. You know it, I know it, and HKS knows it. They're doing something about it, and that is a good thing. Most people want a tune once and forget system. This is their answer.
This, combined with your upcoming engine packages sounds like an unbeatable combo. You'll certainly become one of the top names in 350Z tuning in the near future.
Old Mar 20, 2004 | 12:39 AM
ACP's Avatar
ACP
Originally posted by Guru
The TS reflash will not remap for the 440's at part throttle so I assume he is using E-Manage.
Tadashi is doing a GReddy TT w/ emanage install that starts next week.
It is what I have been waiting for, so he has the ECU reflash for the GReddy w/ 440cc injectors
stay tuned....
Old Mar 20, 2004 | 03:07 AM
mjedens's Avatar
mjedens
Default e-manage
Besides controlling fuel (440 injectors) I'm able to take timing out using the e-manage. (I'm a n2o junkie)
Old Mar 20, 2004 | 07:01 AM
350Now's Avatar
350Now
Default Re: e-manage
Are you using the ignition harness for the E-manage. I thought Greddy mentioned that the timing control does not work with the current 350Z? If you got it to work how is this done?
Old Mar 20, 2004 | 07:13 AM
350Now's Avatar
350Now
The car will need a way of getting more fuel once you introduce more air no matter what (high or low boost). You can use an aux fuel pump to increase fuel pressure but then cram that into the stock injectors, or change the injectors out to bigger ones which Greddy opted to do. Now with the bigger injectors a way of controlling it was needed so that introduce the e-manage.
Too bad they haven't figure out how to incorporate the ignition harness so that we can take some timing off the top.
Sorry to hijack your thread Charles. Keep us updated on how the HKS FCON system turns out.
Jeff
Old Mar 20, 2004 | 12:59 PM
mjedens's Avatar
mjedens
Default E-Manage
Got everything from Ultimate Racing! Ignition wiring,Injector wiring, 440 injectors, fuel pump, and e-manage.
Old Mar 20, 2004 | 01:14 PM
fluidz's Avatar
fluidz
Buy a VORTECH.........
Old Mar 20, 2004 | 01:37 PM
aalzuhair's Avatar
aalzuhair
Originally posted by jesseenglish
Piggyback = a system that alters sensors to trick the ECU into sending out the appropriate engine control signals or alters signals that originated in the stock ECU.
Standalone = a system that has total control of all engine management. Does not rely on ECU to provide anything.
Why is that the "Piggyback" is not preferred?
Thanks,
Az
Old Mar 20, 2004 | 02:58 PM
350Now's Avatar
350Now
Default Re: E-Manage
Thanks for the info.. but does the Ignition harness work with the 350Z?
Old Mar 20, 2004 | 04:20 PM
mjedens's Avatar
mjedens
Default 350Now
Yes it works. I'm not able to advance timing, only take it out. That's what I do for the n2o setup above 5000 rpms , for N/A setup I just leave the timing alone.
Old Mar 20, 2004 | 04:41 PM
phunk's Avatar
phunk
CJ Motorsports
Greddy will be the first to tell you not to run their ignition harness in the 350z. Their RSX turbo kit came with the harness to retard timing on the top, and I know they would have supplied it with the much much more expensive 350z kit if it worked.
I was told that it will cause the coils, or ignitors, or some crap to fail. They must have had some type of problem in their test car... hopefully you will have no problems like this.
Old Mar 20, 2004 | 07:09 PM
350Now's Avatar
350Now
That's what I heard as well. To not use the Greddy ignition harness which caused the coils to fry. They are working on a way to retard timing but it hasn't been release yet to my knowledge.
Old Mar 20, 2004 | 08:34 PM
polar's Avatar
polar
I was going to ask about other pro dealers (specifically if there was one in Texas), but found this page - I think there are more than 4 in the US (Unless this isn't the same thing you're talking about) Congrats on joining the club of pro dealers tho and thanks for the tip on engine management options.
Old Mar 21, 2004 | 03:57 PM
phunk's Avatar
phunk
CJ Motorsports
polar: that is the same thing i am talking about... there are 2 lists tho... I *THINK* that is an out-dated list and is no longer accurate... but I could definatly be incorrect.
The more authorized Pro-Dealers the better.... because then you guys can just pick up our FCON V Pro install kit with base map and then have it tuned somewhere locally without having to ship us your car to have it tuned here in Chicago.
I cant wait for this system to show up... I am confident that it will be a hit and hope that I can use this system to help all you guys in need of greater engine control.
Old Mar 21, 2004 | 07:51 PM
swinke's Avatar
swinke
Thats pretty interesting. Mine has worked perfect for the last 4000 miles with the ignition harness and the timing maps in use. I use it to pull the timing back in the high rpm under boost to take care of the det' problem. Who has had problems burning coils? Did they set the unit up wrong? I got the instructions and ignition RPM harness from Ultimate Racing. Maybe Ultimate Racing is doing something different than Greddy with the E-Manage.
Did anyone ever find out for sure (no guessing please we already did that) if the E-Manage uses MAF signal or injector duty cycle changes when you set up larger injectors?
Old Mar 21, 2004 | 08:18 PM
phunk's Avatar
phunk
CJ Motorsports
swinke: I am no electrical engineer but I would have to think that it is impossible for the E-Manage to drop duty cycle for larger injectors since it only taps into the injector wires rather then intercepts them. IMHO the only way it could do it is by MAF signal drops... which I was also told it did by a tech at Greddy some time ago... who could have been incorrect... but I would have to say it simply must drop the MAF signal... unless someone can tell me why I should think otherwise.
Old Mar 21, 2004 | 08:34 PM
  #38
swinke's Avatar
swinke
You are correct. Sometimes the obvious...well...isn't.
How much do you see your shop charging for the base maps and primary tuning that I am not allowed to do by HKS?
I hate the "no self tuning" part but I really need to get to the next level. ......so really, how much you want for the PRO software? 500...1000....3 hookers and donkey? We can work this out!
Old Mar 21, 2004 | 09:29 PM
  #39
phunk's Avatar
phunk
CJ Motorsports
I couldnt possibly void my contract by releasing the software... its too important to me...
but otherwise... I am not quite sure what final costs will be until our car is at least running with the system. However I will be doing R&D with MAF meters and if its succesful, then we should be able to ship systems that require little to no tuning at all. I would need to know a few details about the engine, such as injector size, and then we could run a MAF system thats capable of greater airflow then stock and its possible that you could just install the kit and need no more tuning... or if you did need more tuning overnight the unit to us for some changes just for your car, then have it sent right back immediatly... or of course just come on down to Chicago where we are or to any other Pro Dealer to have your custom map made from scratch on your car where you can contribute to the tuning.
only time will tell exactly how this is going to work out. I have plans already written out... but its rare that things go as planned so I want to keep my mouth shut until I have something to put on the table for you.
Old Mar 22, 2004 | 06:18 AM
  #40
Ultimate Racing's Avatar
Ultimate Racing
Lightbulb
phunk
The HKS FCON Pro is a fantastic standalone from what I've seen. Definitely on par with most of the top Australian EMS units.
However, I would almost never suggest a standalone ems to a customer unless they knew a great deal about engine dynamics and had good experience tuning standalones.
It's true, standalones are a huge trend right now. For the most part, AEM did a great job in marketing their EMS. We are constantly seeing shops make great power on the dyno using standalones. This is the way it should be. Standalones are fantastic for making power if you know what you're doing. But has anyone thought about what the effects are on daily driving?
In a nutshell, (and I hope this doesn't come out to harsh), any Joe Shmoe can tune WOT but, it take a great deal of patience and know-how to tune the rest.
Most people don't know what they're getting themselves into when they purchase a standalone. They tend to think it's a magical box that will cure all their fueling and ignition gremlins. Let me ask you this though, are you guys prepared to keep a laptop, a wideband, and an array of gauges in your car at all times for the next year? Making changes at every traffic light whenever the idle dips too low or stalls? Not being able to start your car on a very cold morning? All of this NEEDS to be tuned at one point. I have a good friend that drives a Grand National. He's a distributor for the FAST (SpeedPro) EMS system. He's got the unit in his own car and it took him a year before he got 90% of the problems worked out. Even still, the car does not run as well as it did stock.
This is something that scares me. We've been in business for over 12 years now and have met quite a few customers from around the globe. If there's one thing we've learned it's that customers tend to forget they're modifying their car. It will not run exactly as it did stock. There will be some minor glitches here and there that you will have to put up with with.
I have the AEM EMS in my own DSM. Being in cold cold Canada, it took me a little under a week to get the car started and idling nicely this past winter. I'm sure I can easily take it to the dyno now and tune it to make 500whp easily. That would impress everyone wouldn't it? Too bad it will probably stall at every traffic light, and I'll probably have troubles starting it when we start seeing spring time temperatures. Luckily, this is not my daily driver and I have another car at my disposal to get to and from work. These are things that we never hear about but are very much reality.
This is why we use piggyback computers. Bottom line is, you just can't beat the drivability of the stock ECU. Let it handle all the mundane functions that allow you to drive your car normally day in and day out.
A piggyback computer will take us under 2 hours to tune (and that's pushing it) which is why we recommend it to customers. They generally don't want to lose any drivability. If I were to suggest a standalone EMS to a novice, I can guarantee you that I'd be married to the car for the next 6 months at least. I'd be getting calls about just about everything from no starts to rough idles.
In Toronto, we get very hot summers and very cold winters. If temperature was constant all year round then tuning would be easy. Some of you may live in areas where temperatures don't fluctuate as much, but the rest of you are in the same boat as us.
Well thats my 2 cents. Remember though, I am not against standalones at all. I think they are fantastic and definitely make great power. They're just not as easy to tune as marketing dictates. Definitely, not for everyone.
Darryl
