View Poll Results: What Force Induction Method did you choose?
Greddy TT or other turbo based solution
35.00%
ATI Procharger or other SC based solution
13
32.50%
Waiting on others like JWT TT (specify below)
27.50%
Staying NA due to risk or needs
5.00%
Voters: 40. You may not vote on this poll
Forced Induction Your Way
Old Mar 27, 2004 | 03:50 AM
3rdpower's Avatar
3rdpower
Default Forced Induction Your Way
So you have installed or are ready to install your Greddy TT or you ATI ProCharger. Just want to get a sense of why you chose what you chose when it comes to forced induction.
1. What did you choose?
2. What was your reason for going with it?
3. General Cost (or est. including labor)
Old Mar 27, 2004 | 06:23 AM
fluidz's Avatar
fluidz
Procharger, I dont think to many peeps are choosing that unit anymore, Maybe the poll should have VORTECH on there.
Old Mar 27, 2004 | 06:28 AM
jesseenglish's Avatar
jesseenglish
Chose ATI Procharger because it was the only solution out there at the time. If I had to choose between an SC unit again, I'd choose the ATI again because of upgradeability.
However, if I was able to choose Forced Induction again, I'd choose a turbo setup.
Old Mar 27, 2004 | 09:12 AM
mprowe350's Avatar
mprowe350
I picked ATI due to an easier installation and tuning process. I love my set-up and feel good that there is plenty of possiblities to upgrade for more power. If I had to pick again it would still be ATI due to the fact turbos require the install to be done at a shop and not my garage. If I did purchase this again it would have be the "Tuner" kit from ATI and not the "HO" kit. If you are considering ATI then look into the TS reflash and PE 380cc injector set-up for tuning. This leaves absolutly no tuning to do and the A/F ratio and timing are controlled safely by the ECU.
Old Mar 27, 2004 | 09:22 AM
Lugnut's Avatar
Lugnut
Call me a "dreamer," but I am waiting to see if the Dreamworkers kit is for real as I want the low end torque boost and no hood bulge on my G35 coupe.
Old Mar 27, 2004 | 10:18 AM
VampireG's Avatar
VampireG
Waiting on others like JWT.
Old Mar 28, 2004 | 08:41 AM
basam350z's Avatar
basam350z
Odd, you don't have the Vortech on this. I have yet to here anything BAD about this system. I've heard of about 3 blown ATI engines and many belt replacements. TT is cool buy you gotta have the $$$. You can always install the TT yourself, but there are too many things that can go wrong. Supercharger seems like a step above installing an intake, but below changing an alternator. my 2 cents
