Stillen Supercharger (Belt Issues)
I have an issue that I have been trying to chase out ever since I got the car, and now it's driving me crazy. I have a squeeky supercharger belt (or, so i think).
My question is, Do any of you have a Stillen S/C and if so, do you or have you ever had any issues with it like this..
Also, even if any of you DON'T have a S/C, do you get any squeeky belt problems?
It's hard to pinpoint the squeel, if it is in fact coming from the S/C belts or if its coming from one of the serpentine belts..
I have tightened and loosened this belt so much and so many variations in between, that I have no clue what's too tight, and what's not enough... I have even put belt dressing on it, and that does absolutely nothing. - I really don't like the idea of the belt dressing period. -As that would make the belt slip instead of stick I guess. and "slipping" on a S/C belt means bad news because it's not fully turning it anymore.
Do any of you have any ideas or whatnot about this??
I will have to check with Stillen I guess if there is nothing else that can be done.
I have a slight squeal at start up, and only at startup when my car has sat for a week or 2, and I think its the s/c belt, but I haven't gotten around to messing with it, because thats the only time it does it, and I have been busy. I would start with the s/c belt and then move on to the others, tightening progressively til the squeal goes away.
I am awaiting a Vortech SC, but I think I read in a post within the last couple of days, if you can take the belt and twist it and see the bottom side, it needs tightening. Might have been in a Vortech post, but assuming the same applies.
Ok well, I narrowed it down to the serpentine belt! I get a quick squeel at start up too, and then a chirp, chirp, chirp, chirp for about 10 seconds now after putting on some more belt dressing a bit ago. I put a weight on the pedal and went and listened for the point where the sound was coming from, and it sounds like its doing it on the left side where the power steering pump is at.
It also will chirp, chirp, chirp when I max out the steering wheel's turn radius.
I need to know if there is an adjustable tensioner on the engine, and if so, where it's located. I think I may have found it, but just want to confirm that.
there is a tensioner for each of the 2 belts. you need to loosen the belt on the center of the tensioner pulley first, then adjust the tension with the bolt you access from the bottom. after tightening, retighten the bolt in the center of the puley.
Stillen charger, yes
stillen charger problems, no
350Z_Al
Oct 29, 2020 07:44 PM
350z, belt, dressing, issues, problems, pulley, replacement, slip, slipping, stillen, supercharger, superchargers, tensioner, tight, tuning
