Analyzing TDO5-18G greddy turbos on a built motor
Old Jul 28, 2004 | 10:19 PM
Jeff@Evolution's Avatar
Jeff@Evolution
Nice thread.
Old Jul 28, 2004 | 11:35 PM
SQUILL's Avatar
SQUILL
UGH !!!!!!!!!! gurgen i just finished working on the flow chart and noticed when i was converting bar into psi that the PE compressor chart starts off at 1.2 bar instead of 1 bar like everyother compressor chart!!!!
so now all my hard work is ruined!!! ill have to fix it tomorrow but i have to say that these turbos look to be very well chosen for the VQ motor and look like they will support a max of 18 psi @ 7000 rpm which should develop a very healthy 550 + whp on a lower compression built motor i would guess.
Any way i have to redo the entire chart ill post it up tomorrow...sorry shoulda looked more closely!
Old Jul 29, 2004 | 12:10 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
hey
actually i am working on a version myself... but running into some problems. Not sure how that x-axis is scaled (m^3 times 3?) B/c if it straight, soemthing is wrong with my excele chart. Too tired... looking forward to yours.
Old Jul 29, 2004 | 12:30 AM
SQUILL's Avatar
SQUILL
Originally posted by gurgenpb01
hey
take x cm3 per min (cubic meters per minute) x 35.31467 to get cfm or cubic feet per minute
so 6 cm3 per min = 211.88 cfm. (6 on the bottom of the chart)
Old Jul 29, 2004 | 05:47 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
yeah that's what I did, but I am getting a really weird chart.
Old Jul 29, 2004 | 05:57 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Here is what I am getting. Something is wrong
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-untitled-1.gif
Old Jul 29, 2004 | 07:18 AM
JeffesonM's Avatar
JeffesonM
any interest in doing one for the Vortech V2?
Old Jul 29, 2004 | 08:15 AM
Juztin's Avatar
Juztin
Request for Squill :
Can you possibly due a map for a TD-06, and GT35 (I'm considering doing a single turbo)
--j2
Old Jul 29, 2004 | 09:30 AM
SQUILL's Avatar
SQUILL
gurgen you have the right idea however assuming your plots are correct ( cfm demand starting at 1.2 bar and them cfm at 2.4 bar would be easiest to plot your points) you must divide your plots by 2 as there are two turbos!
hee hee im sure thhats what happened!
Old Jul 29, 2004 | 10:04 AM
SQUILL's Avatar
SQUILL
OK i finally got it done here is the pe chart
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-plowchart.jpg
Old Jul 29, 2004 | 10:08 AM
SQUILL's Avatar
SQUILL
--j2
no problem in fact i might have done a gt35 already ill have a look
Old Jul 29, 2004 | 10:50 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
ahhhh. doh!
Old Jul 29, 2004 | 12:37 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Hey Guys
Here is my version. I also added some curves to give you an idea of the spool up that I see in my car wth these turbos.
G
EDIT: Actually, I am a little unsure of the spool up time in 1st gear - but that represents the worst case scenario. I'd almost bet that the spool up begins a little earlier, but again, not sre. Will double check when i get the car back
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-pe1420-compressor-map-with-.gif
Old Jul 29, 2004 | 04:42 PM
SQUILL's Avatar
SQUILL
--j2
hEE hee the gt35 looks to bee a little small!
1.2 bar = 3 psi
1.4 bar = 6 psi
1.6 bar = 9 psi
1.8 bar = 12 psi
2.0 bar = 15 psi
on any compressor chart 1 bar = normal atmospheric pressure so 1 bar on the chart = N/A
2 bar on any compressor chart = 1 bar of normal atmospheric pressure plus 1 bar of positive boost pressure or 2 total atmospheres which equals 1 bar of positive boost pressure or 15 psi roughly of positive boost pressure
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-garrett35fc-copy.jpg
Old Jul 29, 2004 | 05:06 PM
SQUILL's Avatar
SQUILL
Here you go!
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-superfc.jpg
Old Jul 29, 2004 | 10:40 PM
SQUILL's Avatar
SQUILL
--j2
The td06 20g compressor map is similar to the gt35 compressor map and is way too small for the vq motor.
Have a look at the vortec compressor map that i did.
you can see that a single turbo needs to be able to produce 800 to 900 cfm for the 3.5 l VQ.
ill look for a turbo that might be a good fit .
Old Jul 29, 2004 | 11:02 PM
SQUILL's Avatar
SQUILL
--j2
Ok Juztin how bout a single garrett gt42 snail on the vq block!
not only does it look good for lower boost pressures but how about 27 psi @ 7000 rpm on a built motor in the future!!
Old Jul 29, 2004 | 11:03 PM
  #38
SQUILL's Avatar
SQUILL
oops forgot the pic!
Attached Thumbnails Analyzing TDO5-18G greddy turbos on a built motor-gt42-comp.jpg
Old Jul 30, 2004 | 04:38 AM
  #39
PoWeRtRiP's Avatar
PoWeRtRiP
the turbonetics one for their single is actually a 60 trim opposed to the gt42 56 trim you showed. could you post up a chart of that one i believe they have maps on their site.
thx in advance.
Old Jul 30, 2004 | 02:25 PM
  #40
Juztin's Avatar
Juztin
Wow that GT42 looks like a good candidate . Ball bearing ooohhh. Only thing is that sucker is 2g's! Ouch lol. Looks like at even ~7psi it'd be flowing as much as 500cfm albeit with not great effeciency correct? There's nothing smaller that could really flow enough air to support say ~400 wheel at a max of ~9psi? hmmm
