Fuel cut problem w/ Vortech...help!
Old Aug 2, 2004 | 02:36 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Default Fuel cut problem w/ Vortech...help!
Ok, so i was driving today on the highway i saw that there were no cars so i decided to play around a bit. So i punched it in 3rd gear and when it went to about 4500 rpm, the engine stopped like it hit fuel cut. I decided to do it again in 4th gear, and at about 4500 rpm, it did it again. I dont know what the problem is. this happened before when i first installed it, but it happened because the wire that went to the power in the ecu was loose, so we soldered all the wires together. I dont think it could be that again. could it??? So now i am at home trying to figure out what went wrong...any ideas????
thanks in advance!
Old Aug 2, 2004 | 02:55 PM
zimbo's Avatar
zimbo
It sounds like the aux pump is not coming on.
Have you uploaded any changes from your laptop to the SS box? If not then it's likely a wiring or MAF problem. Or perhaps the vacuum line on the FMU has come out.
I would attempt to connect to the SS box via a laptop and do a recording to see what it is seeing at various RPMs.
--Steve
Old Aug 2, 2004 | 02:59 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Is it possible for it to start happening just now? seems like an aux pump is a problem that i would have when i first installed it? anyway, i have not changed anything in the ss box since i got it tuned 3 weeks ago, but i havent checked on the vacuum lines yet...ill check everything and keep you posted, meanwhile, any more ideas???
Thanks
Old Aug 2, 2004 | 03:39 PM
teh215's Avatar
teh215
Check the fuse?
Old Aug 2, 2004 | 05:25 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
the fuse is fine, i am going to replace all the vacuum lines with fuel lines in the morning, i remember someone posting something about that because the lines that come with the vortech are real flimsy and can work their way loose...hopefully i will find the leak....
Old Aug 2, 2004 | 06:20 PM
lorinserbenz's Avatar
lorinserbenz
I bought the screw type fuel injection hose clamps and put wire ties on all the vacuum hoses. I wouldnt use the clamps that came with the kit..
