Vortech....Some thing strange happened...Help !!!
Old Sep 9, 2004 | 06:27 PM
dfw350z's Avatar
dfw350z
Originally posted by booger
Could you send me your maps when you can ?
Sure thing.. I hope to have the ride at dyno this Saturday, that is if they finish the re-install on time ???
Old Sep 9, 2004 | 07:46 PM
350zer's Avatar
350zer
Like I said , I did another run the same day it happened , in 3rd to 6,300 rpm's....boost was 7.3 but I didnt get into boost [WOT] till I had passed 3,500rpm . SO I think thats why it wasnt in the 7.6 to 7.8 range as normal . No smoke what so ever on that run . The blower [ or jackshaft] could be going Its making more noise than normal
check the ATF hose that goes from the block to the bottom of the radiator. the intercooler tube pinched my and i was blowing all kinds of smoke down the freeway. thought i popped the oil filter i had so much oil coming from under the car until i smelled it and it was ATF. then i knew were the problem was because the intercooler line is right against the cooler line.
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
