Stillen Stage 2 .. Am I too lean?
Originally posted by 2003z
thats probably pretty safe. The richest I have seen on my stage 3 is 11.5 during the 1/4 mile, but its usually low 12s.
The last dyno I did I was running 6.5lbs at redline ...
Colin
Read the chart, not the max numbers.
You're ok IMO if the reading was taken at the exhaust tip. Figure on around 6-8% lower numbers in the engine, unless the dyno operator used some correction.
Originally posted by axxizzer
eyah, you might want someone to tune in a bit more fuel
17.5 is really lean
try for around >13
17.5 is really lean
try for around >13
