What mods make turbo's spin faster?
Old Sep 27, 2004 | 10:02 AM
Jax350z's Avatar
Jax350z
Default What mods make turbo's spin faster?
I have heard that possibly lightwieght crank pulley, and lightwieght clutch/flywheel help.
Is there any truth to this? Also, what other mods help spool time?
Old Sep 27, 2004 | 10:12 AM
myz8a4re's Avatar
myz8a4re
large downpipes after the turbo help spool-up greatly!! you can also have the impeller fins clipped to inrease spool-up but this reduces the life of the turbo. i did both on my zxtt with great results..........
-justin
Old Sep 27, 2004 | 10:23 AM
azrael's Avatar
azrael
lightweight crank pulleys and flywheels reduce parasitic drag on the engine's crank, and will result in a more responsive engine -- i.e. the engine revs up more quickly in response to throttle input.
These things may help turbo spool time somewhat, but will not make the turbo spin more quickly. The speed of the turbo's compressor wheel is related to the exhaust gas flow and the actuation of the wastegate.
Old Sep 27, 2004 | 12:47 PM
accordfreak's Avatar
accordfreak
Nitrous Oxide
Old Sep 27, 2004 | 01:40 PM
G3po's Avatar
G3po
Default spool
Originally posted by accordfreak
Nitrous Oxide
Thermsal coating (usually ceramic) the Exhaust manifolds, impeller housings and downpipe ,can improve Turbo spooling. More heat coupled to the impeller . more reponsive the boost profile..
Old Sep 27, 2004 | 02:23 PM
turbo-maxima's Avatar
turbo-maxima
Default Re: spool
ya ceramic coating should help also a free flowing 3 inch exhuast and cat. Nitrous works well too but 350z sure do like to throw rods.
Old Sep 27, 2004 | 03:26 PM
dynamic6er's Avatar
dynamic6er
Port and polish of head, manifold, exhaust housing, and downpipe. Extrude hone those hard to reach areas like the manifold and the interior of the DP. Ball bearing turbos should spool faster, but that depends more on matching turbo size to the engine.
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
