My Vortech rattles like a can of spray paint
Old Sep 30, 2004 | 12:48 PM
CaneZMD's Avatar
CaneZMD
Default My Vortech rattles like a can of spray paint
My Vortech SC/jackshaft area rattles like crazy!
It really sounds like when you shake up a can of spray paint. I can't tell whether it's coming from the jackshaft or the SC because I don't feel like sticking my hand or head down in there
when it's running.
I called Vortech and they said "maybe you overtensioned the serpentine belt and burned out the jackshaft bearing", but with my stretchy piece of crap goodyear gatorback belt, I think that's impossible. Then they said to try tightening the hex bolt on the SC gear, which I guess I'll try.
So two questions:
1. Anybody have this spray paint can rattle? and how did you fix it?
2. Where can I find a gates belt for this SC on the net, because no one in South FL seems to carry gates.
Old Sep 30, 2004 | 01:01 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I assume your talking about this sound at idle and cruise..right? Not detonation.
Old Sep 30, 2004 | 01:05 PM
teh215's Avatar
teh215
I had a sound similar to what you described. The bolt that holds the 6 groove pulley on to the fron t of the jackshaft was loose. Tightening it made the soud disappear.
Old Sep 30, 2004 | 05:48 PM
tig488's Avatar
tig488
mine does it at low idle rpms below800, mine did get much better when i loosened the adjuster pulley, the pulley on the back of the bracket in the middle, you dont want that real tight, tightening the sc hex doesnt help at all.
Old Sep 30, 2004 | 08:19 PM
CaneZMD's Avatar
CaneZMD
I'm gonna mess with it tomorrow.
Yea, GQ, I should have clarified that, It's at idle and low rpm.
If it was detonation, my thread would have a whole different title!
Old Oct 1, 2004 | 10:03 PM
CaneZMD's Avatar
CaneZMD
I fixed 90 percent of the noise. The screw bolt that holds the notched pulley onto the jackshaft was very loose. (from the factory) I tightened it and it's pretty quiet now.
Old Jan 5, 2005 | 07:30 PM
backagain's Avatar
backagain
i have the same issue, iknow this is an old thread, but the bolt keeps coming lose. should i use thread lock on this to keep it tight ? or is this a big no no ?
Old Jan 6, 2005 | 05:22 AM
NismoGCoupe's Avatar
NismoGCoupe
Im not sure if you would be willing to do this but you can have someone tack weld it, that would definetly solve the problem
Old Jan 6, 2005 | 10:50 AM
booger's Avatar
booger
backagain.....Did you try calling Vortech and see what they say about using thread lock on it ? I dont see why you couldnt , just dont use the stuff thats real strong .
Old Jan 6, 2005 | 11:12 AM
tig488's Avatar
tig488
i used threadlock, it was permatex blue, i did it about 2 months ago and it hasnt loosened up again, at least i dont think it has, i forgot about it.
Old Jan 6, 2005 | 02:54 PM
backagain's Avatar
backagain
will use thread lock on it, thanks, one more questoin about the bolt though ? can i back it all the way out or will the pully fall off if i do this ? i wasn't there for the install so i don't know how far i can back this bolt out.. thanks
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
Cashwin
Oct 1, 2015 06:36 AM
