R4 and Vortech Tuning
Old Oct 28, 2004 | 03:02 AM
Barzten1's Avatar
Barzten1
Default R4 and Vortech Tuning
Had my car at the dyno today getting tuned with the R4 software. Made over 30 runs and a/f still not right. Best run was 339whp but a/f was not quite right. I think I got alot less once it was all said and done but I was wondering if there was some sort of map or guidline they could use to make the process easier? Kept the performance guys there all night trying to get it right. Hp kept dropping with every run because of heat issues.
Old Oct 28, 2004 | 05:06 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
hey everyone...
isn't dynoing a car pretty streneous on the drivetrain/clutch???
i mean repeated dyno runs...
just curious?
-barzten: it'll all be over soon, then you can take a deep breath and finally smile... don't worry, the day will come.
Old Oct 28, 2004 | 06:30 AM
dynamic6er's Avatar
dynamic6er
Couple of suggestions:
Get rid of the Iridiums, they can't be gapped properly
Did you use dyno wide band or AEM? If you used the dyno wide band have your tuner make sure the sensor is not worn out. (If the've been runing c16 or any leaded fuel then most likely it is)
I didn't see a fuel pump in your list. Has that been upgraded? (the tank pump not the Vortech)
Last possibility is the ECU needs to be reflashed. If the computer is modifying the maps internally then the Split Second can't do anything about it. (I doubt this, we have not had any real problems with this when we tune the Vortechs).
Hope that helps!
Dave
Old Oct 28, 2004 | 06:58 AM
booger's Avatar
booger
Default Re: R4 and Vortech Tuning
Barzen...what was your A/F ? The R4 has one draw back....it goes by 500rpm increments . So it kinda hard to get it stable . What kind of Dyno did you use ? If it was a Mustang dyno....your hp is good...30 runs ...is alot of dyno time and I think you should have stopped after about 10 or 12 . Heat soak can hurt hp quite a bit ....Bill
Old Oct 29, 2004 | 06:40 AM
Barzten1's Avatar
Barzten1
Got it back today and this was my best pull. I'll settle for these #'s for now
Old Oct 29, 2004 | 06:49 AM
booger's Avatar
booger
That pretty dam good
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
