vortech owners HELP?
Old Oct 29, 2004 | 02:31 PM
350nt's Avatar
350nt
Default vortech owners HELP?
i've had the kit on for about 3months or 3000miles, its all stock, just has the vortech. i was going to keep it like that cause i daily drive the car(i also have the ings half kit and 19" sf challange, was going just for looks) but now the car doesn't feel fast anymore. i want alot more power, something that will get that fast feeling back, so my question is what parts should i get (i have the r4 program already, just haven't had time to take it get tune)
some parts i have been thinking about are the fujitsubo y pipe and exhaust or should i go with the nismo full exhaust (or what exhaust makes the most power). should i go with high flow cats or test pipes, does the test pipes give you a check engine light? and my last big question should i get a plenum? what plenum is the best, will it crack and does it help make alot of power?
what do you guys think my car is making right now and what else do i need to get to 400 or more rwhp (without cams)?
thanks for reading the long *** post and thanks for any info!!
Old Oct 29, 2004 | 02:45 PM
LOU's Avatar
LOU
Best bang for buck would be a smaller pulley.
Old Oct 29, 2004 | 02:49 PM
teh215's Avatar
teh215
Plenum, hi-flow cats and exhaust.
Old Oct 29, 2004 | 02:54 PM
tig488's Avatar
tig488
totally different car with the 3.12 pulley
Old Oct 29, 2004 | 02:59 PM
teh215's Avatar
teh215
That is the pulley that everyone refers to as the "9 lb pulley", correct?
Old Oct 29, 2004 | 05:47 PM
aron's Avatar
aron
I gained 30whp when my tuner use the R4, also u may need to get a new belt to get some boost back, but yes a smaller pulley would be the way to go. Tig488, what size belt is needed for the 3.12 pulley, and what were your gains by switching to that pulley, assuming you have that one?
Old Oct 29, 2004 | 06:03 PM
dfw350z's Avatar
dfw350z
I agree..
1. Replace all belts - slippage will kill hp.
2. Get the 9lb pulley
3. Get the car tuned
Old Oct 30, 2004 | 01:54 AM
booger's Avatar
booger
A 93 inch belt will work for the 3.12 and 2.87 pulley's . Get the Gates belt....thicker , stronger, stretches less . And yes...Best thing to do is get the car tuned
Old Oct 30, 2004 | 06:30 AM
tig488's Avatar
tig488
exactly as boog said. yes i do have the 3.12 (9lb)
Old Oct 30, 2004 | 06:34 AM
Barzten1's Avatar
Barzten1
So is the 3.12 pully less safe? How much gain do you get from adding this?
Old Oct 30, 2004 | 07:02 AM
booger's Avatar
booger
Your probably in the 300whp range now , tuning will get you 320 to 340 , the 312 pulley will get you 360 to 390whp . This all depends on your tuner and the dyno you use while tuning ,If your tuner doesnt have a knock sensor to use while tuning ,dont take out less than 7 degrees of timing out at 8lb's of boost and above . I tried and broke a piston . All the number depend on what kind of Dyno you are on also . I used a loaded Mustang Dyno...set for a 3,700lb car and got 351whp, a dyno jet would show me at around 390whp {well not any more...its broke for now }
Old May 27, 2006 | 08:04 PM
charged's Avatar
charged
Best pully kit to buy and where?
Old May 28, 2006 | 02:21 PM
schweatty's Avatar
schweatty
holy ancient thread, batman!!
Old May 28, 2006 | 06:57 PM
booger's Avatar
booger
No Chit...old
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
