P0300 - Random misfiring code
Old Nov 9, 2004 | 11:57 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default P0300 - Random misfiring code
Hey guys just got back from the shop and the code reads: P0300 - random misfiring, Okay to drive. Thats what it has on the scanner. Anyone know how I can fix this so I dont get a SES light?
Old Nov 10, 2004 | 03:20 AM
nitrous350's Avatar
nitrous350
this is What i get from Service Manual
DTC No. Trouble diagnosis name DTC detecting condition Possible causeP0300/0300 Multiple cylinder misfire detected
Improper spark plug
Insufficient compression
Incorrect fuel pressure
The injector circuit is open or shorted
Fuel injectors
Intake air leak
The ignition signal circuit is open or shorted
Lack of fuel
Signal plate
Heated oxygen sensor 1
Incorrect PCV hose connection
Cause i Had a Same Problem but only at idle RPM = NO Problem Driving ( even with NOS )
I think i had a problem with Fuel Pressure or Spark plug
cause right after i changed the 255lph SARD pump and #4 colder HKS plug
i had SES light and also my F.P is very High around 72psi at idle
F.P should be 51psi at idle
Old Nov 10, 2004 | 06:03 AM
etx's Avatar
etx
Most likely a vacume leak somewhere. Check your intake gaskets and fuel injector o rings. Remember, Nissan uses compression gaskets so they are NOT reuseable.
Old Nov 10, 2004 | 06:08 PM
nitrous350's Avatar
nitrous350
aaaaa....
Thank's
Old Nov 11, 2004 | 11:51 AM
cquence 350 [Z]
For some reason, I took my car back to the shop and have them check out my engine (I heard like a hissing sound coming from the passenger side of the engine). Well he tried to see if there was a leak so he unpluged the vac. hoses and messed around with it. He said that there was no leaks but he did hear the sound. Anyways, after we were done and I drove off, I noticed my SES light went away. Would you think it was a vac hose leak? Hopefully the SES light stays off (crossing fingers!)
Old Nov 11, 2004 | 12:53 PM
etx's Avatar
etx
A vac leak could cause that. Any extra air after the MAF will cause the mix in the cyl to be lean.
Old Nov 11, 2004 | 01:30 PM
cquence 350 [Z]
ya but my AF mixture is untuned and it is running real rich at 9.8. I am going to have it retuned to an 11.5
Old Nov 11, 2004 | 02:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
too rich can definatly cause a periodic misfire.
Old Nov 11, 2004 | 04:31 PM
Speedracer's Avatar
Speedracer
Default Re: P0300 - Random misfiring code
My SES light is on also. Misfire should give a blinking light, right?
Mine is continuous. Getting it looked at tomorrow. That's one of the biggest problems with FI systems....diagnosing a problem. You don't know if it is a stock issue or some problem caused by the piggy back or some hardware issue. Anyway, an occasional random misfire is no big deal. I've also just ordered the Digimoto Scan Tool. Not a bad deal for $170 including software, OBD port interface and USB-to-serialconversion cable.
www.digimoto.com
Old Nov 11, 2004 | 10:28 PM
350G's Avatar
350G
Misfire (non detrimental ones) do not give a blinking SES light. If you ever experience a blinking light, stop your car. A solid light means you should have it checked soon, but its not going to blow up in most cases I am also a member of the P0300 code. I drive for about 15 miles and it disappears. And for the record, I have an untuned setup for the moment (greddy).
G
Old Nov 11, 2004 | 10:57 PM
AmyCroft's Avatar
AmyCroft
Smile Question - Status of lights on E-Manage
Could you sneek a peek at the lights on the E-Manage
What do you see the lights doing?
Cheers Amy -
Old Nov 12, 2004 | 03:15 AM
cquence 350 [Z]
I dont have the lights on anymore. For some reason I think it was a vacume hose leak. The guy at the shop was messin with it and the lights went away after I drove off. If it does come back on, I will sneak a peak at it and I will keep you guys posted.
Old Nov 12, 2004 | 01:36 PM
cquence 350 [Z]
Doh! it just came back on today!
Old Nov 12, 2004 | 01:53 PM
nitrous350's Avatar
nitrous350
so how about Fuel Pressure ????
is not cost of SES light ????
etkms
Jun 19, 2022 06:30 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
