Potential problem with '04.5 ECU's and F/I systems....
Old Nov 27, 2004 | 07:51 AM
  #41
techz33's Avatar
techz33
Originally posted by Speedracer
All I know is that with my HKS F-CON that came pre-programmed with the HKS SC kit, the diagnostics showed the air:fuel ratio on both pre-cat sensors to be 20% richer than the stock "spec" setting. The correctable range for the stock ECU is +/- 12.5%. More than this will trigger an SES. The problem is that neither I nor the Nissan Master Tech who looked at my car had any info on what that actual "spec" A/F is supposed to be for any driving condition. I have contacted HKS and they are looking into it. All their R&D was done on a 2003 model and so the ULEV engine management was not an issue. To their knowledge, I am actually the first person to install the kit on a ULEV spec 350Z.
Im in the same boat.....
Old Nov 27, 2004 | 07:53 AM
  #42
techz33's Avatar
techz33
car starts to sputter in 3rd and 4th gear at about 3600-4000rpm
XS engineering is working with me in soliving the problem i will keep you posted on the buff ecu
Old Nov 27, 2004 | 02:27 PM
  #43
Speedracer's Avatar
Speedracer
Originally posted by Z1 Performance
Also, where in the manual does it say 100% LTFT is fail safe...makes no sense whatsover to me. On every car I have ever datalogged (regardless of maker), 100% stft and ltft corresponded to the car running the way the ecu wants it to. Any number below 100% was the car running slightly richer than stock, any number above 100% was the car running slightly leaner than stock. I remember this from back trying to get my VPC to play nice with my SAFC on my Galant VR4. A stft of 75% would throw a CE light on that car too (it's a '92!), and the car would run like doo doo. If you leaned the SAFC out, you could literally watch stft trim eek back towards 100%.
VJ - try logging just 02, one sensor at a time, one bank at a time, and post here what it does at idle (once the car is warmed up), under cruise and under WOT. Do the same thing for each sensor in each bank and post what you find. Would also be interesting to see what fuel pressure is at idle as well. Remember, the HKS setup has an upgraded pump but no return system
Adam,
It would be REALLY REALLY REALLY great if you could come up next weekend to help figure this all out when we run data on the dyno with several people involved. See what you can do. Isn't there a ferry that will get you pretty quickly to Connecticut?
Also, according to my Fuel Pressure gauge which is located immediately after the fuel damper in the bung that splits off the fuel supply for the auxillary injectors, the pressure is 51-54psi constantly, from idle up to redline at all throttle positions.
Old Nov 28, 2004 | 08:16 AM
  #44
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
VJ - I will see what I can do. yes the ferry is a quick trip to CT but Wethersfield is far from everyplace Plus weekends are family time, so gotta see if I can break free for a day (maybe send her holiday shopping!)
FP is good
Old Nov 28, 2004 | 09:21 AM
  #45
002-M-P's Avatar
002-M-P
Your sig says you are running the HKS F-Con V-Pro, which I believed to be completely stand alone (correct me if i'm wrong), so why would this effect your car if it doesn't even have the factory ECU.
Old Nov 28, 2004 | 09:22 AM
  #46
Z1 Performance
Former Sponsor
well with the F Con you do retain the factory ecu, but you are right...if that's what he has, it's in his tuning and unrelated to this topic
Old Nov 30, 2004 | 01:50 PM
  #47
Severed Ties's Avatar
Severed Ties
Any new info on this? Was planning to go forced induction in the spring but not if the ECU itself is the problem rather than the tuning???
  #48
Severed Ties
sorry my comp always double posts and I can't delete them.
Old Nov 30, 2004 | 02:30 PM
  #49
Speedracer's Avatar
Speedracer
I'll post my dyno results and data logging after Dec 4. A system properly designed on a ULEV2 vehicle should be okay (APS TT). The problem is that most of the current kits out were not developed and tuned on ULEV2 cars. The real trick is is running rich enough to be safe , but fool the ECU into thinking you are lean enough not to trigger the SES light in the late model vehicles whose ECU's maintain very tight A:F ratio control.
Old Dec 1, 2004 | 08:38 AM
  #50
Severed Ties
Good to know, I was planning to go the supercharger route as the APS kit is just to expensive but I guess I'll see whats available in the spring.
Thanks for the update.
Old Dec 1, 2004 | 09:26 AM
  #51
MIAPLAYA's Avatar
MIAPLAYA
Turbonetics is also tuning on a Ulev2 computer...mine///
Old Jan 21, 2010 | 03:27 PM
  #52
jonnylaw's Avatar
jonnylaw
Sorry to bring an old thread back to life.
I have HKS GT SC setup with fcon vpr and uprev reflash. My ide is jumpy and I have been throwing p1281 code. I had the driver's side sensor in the manifold replaced, and it went away for awhile. But now I am throwing it again.
Has anyone who has experienced this issue come up with a solution? I don't want to have issues with emissions next time I have to go.
Old Jan 22, 2010 | 02:47 PM
  #53
MDK's Avatar
MDK
It's pretty easy to disconnect the SC and ECU and have the car ready to pass emissions in a few days.
Old Nov 2, 2010 | 07:12 AM
  #54
kramykram's Avatar
kramykram
yup yup bringing old thread up again myself. code p1271 and p1281 coming up. we want to head to forged in the next couple of weeks for a tune but want to get the codes cleared first. this has a stillen supercharger on it. so any help would be great.
Old Nov 2, 2010 | 02:31 PM
  #55
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
PM sent.
Old Nov 3, 2010 | 01:32 PM
  #56
rh_334's Avatar
rh_334
so your running a stillen supercharger on the stillen box right now? or is it tuned with something else? and based on your codes it sounds like you have 2 bad 02 sensors
Old Nov 3, 2010 | 03:19 PM
  #57
kramykram's Avatar
kramykram
Talked to chuck @ stillen he told me to pull the 7th injector and make sure its closing if not I need new injector and it has caused all the sensors to file out. Yes has the black box. I was told the car will not run without the box even with a tuned ecu
Old Nov 4, 2010 | 11:30 AM
  #58
kramykram's Avatar
kramykram
Wow to find out after talking with chuck@stillen again. He is telling me the black box is bad. But hey guess what. they do not use the black box anymore. Now they want to sell me a new $900 piggyback I supposed it is. What a crock of crap. So you updated and now the consumer has to pay out the ***? I know you gotta pay to play and glad it is not my car but it is one of my boys and thats just bs. Anyone else out there running the stillen supercharger with a tune and aftermarket injectors to bypass this bs black box??
Old Nov 4, 2010 | 11:55 AM
  #59
rh_334's Avatar
rh_334
talk to Jon@Z1 (Ext.311) i think he said hes done it before
Old Nov 4, 2010 | 12:11 PM
  #60
kramykram's Avatar
kramykram
ok thanks
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
