Another day, another failed rod :-(
Old Nov 20, 2004 | 01:11 PM
Lorca@Z1's Avatar
Lorca@Z1
Default Another day, another failed rod :-(
**cough**
Carrillo, 8 second 1/4 mile pass, 1300whp
**cough**
Old Nov 20, 2004 | 01:53 PM
booger's Avatar
booger
Who's car did that come out of ? Nasty looking bend . Surprised it didnt snap
Old Nov 20, 2004 | 02:08 PM
aron's Avatar
aron
yuck....keep that boost down
Old Nov 20, 2004 | 02:09 PM
Lorca@Z1's Avatar
Lorca@Z1
Core motor that overheated and was replaced under warranty by Nissan
Old Nov 20, 2004 | 03:44 PM
G3po's Avatar
G3po
Default rods
Looks just like the 2 bent rods out of my core block.
My core motor bent rods with a poorly tuned Greddy running <8.
Does't take alot of boost to bend the OEMs, just detonation
Old Nov 20, 2004 | 04:25 PM
azrael's Avatar
azrael
looks nasty
btw, what does a core motor that overheated have to do with carillo rods and an 8 second pass? I don't see any carillo rods in those pictures.
Old Nov 20, 2004 | 05:42 PM
Lorca@Z1's Avatar
Lorca@Z1
Originally posted by azrael
looks nasty
LOL, it was a not so subtle suggestion that if you use Carrillo rods you won't see this happen to you as evidenced by the Z that made an 8.33 second pass using Carrillo rods and making 1300whp. Maybe it was too subtle if you didnt get it ?
Old Nov 20, 2004 | 08:01 PM
phunk's Avatar
phunk
CJ Motorsports
yea i was confused by the carillo comment as well?
Old Nov 20, 2004 | 10:49 PM
AmyCroft's Avatar
AmyCroft
Default Yes - You were not Speaking Clearly
Too darn Subtle - to be understood - At least there were no Carrillo Rods Shown... But then again it was not funny.
Cheers Amy -
cc:Funny@Subtle.com
Old Nov 21, 2004 | 05:17 AM
uro279's Avatar
uro279
What's meant by 'core motor'? Are you just simply talking about the engine itself overheating? If so, I thought that with APS, this kit was designed so as to avoid overheating. So the second question would be, why did the core motor overheat and did you notice the overheating in the guage?
Old Nov 21, 2004 | 05:33 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Default Re: Another day, another failed rod :-(
**cough**
**cough**
LOL...seems to be a trend. Out of the 8 core motors we have 5 of them had bent rods
Old Nov 21, 2004 | 06:34 AM
cjb80's Avatar
cjb80
Default Re: Re: Another day, another failed rod :-(
If the tune isn't right then you can bend even aftermarket rods... sounds to me like the emanage isn't a good solution for engine tuning, or they aren't tuned right out of the box.
Chris
Old Nov 21, 2004 | 06:52 AM
Enron Exec's Avatar
Enron Exec
Default Re: Yes - You were not Speaking Clearly
Cheers Amy -
cc:Funny@Subtle.com
I couldnt find that website: http://www.google.com/search?hl=en&q=Funny@Subtle.com
Is my internet broke?
Old Nov 21, 2004 | 08:04 AM
flynnibus's Avatar
flynnibus
Z Flier
define 'core motor'. Are these blocks you guys are buying?
Old Nov 21, 2004 | 08:31 AM
G3po's Avatar
G3po
Default core
A "core" means an old long or short block to be used for rebuild.
In this case a forged bottom end rebuild specifically for FI. For example a shop will generally credit a customer ~$2k fro a rebuildable core. This overheating appeared to happen on an OEM block , no FI (specifically no APS kit was involved).
Old Nov 21, 2004 | 08:36 AM
G3po's Avatar
G3po
Default Re: Re: Re: Another day, another failed rod :-(
Chris
With a bad tune, something else will give well before Pauter rods. and maybe even Carillo A-beams. Most likely rings, piston or head gasket would go first. Personally I have never seen a bent Pauter.
Old Nov 21, 2004 | 06:40 PM
Lorca@Z1's Avatar
Lorca@Z1
Default Re: core
Exactly, this was a motor that was replaced under warranty by Nissan on a non-FI car. We bought the motor to use as a core for a build up because the rods and pistons are being replaced and there was no damage to the block itself, just the stock rod as indicated in the picture.
Really not sure how APS got thrown into the mix, but this has been the most misunderstood thread ever
Old Nov 21, 2004 | 07:12 PM
flynnibus's Avatar
flynnibus
Z Flier
still confused.. you bought it with the bent rod.. or you bought it.. ran it.. and then bent the rod.
I'm guessing this is you bought the block.. and took these after disassembling it.. on your way to building it up for something else.
Old Nov 21, 2004 | 07:44 PM
uro279's Avatar
uro279
Default Re: Re: core
Sorry about the 'APS' confusion. I assumed you had it because it's in your sig!-I just missed the fact that it said 'coming soon'.
Old Nov 21, 2004 | 07:47 PM
uro279's Avatar
uro279
If the engine was OK except for the rod and piston, then why did Nissan replace it?
