Stock 19" wheels weight?
Old May 1, 2006 | 03:42 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Originally Posted by engiNERD350Z
+1. Think about propane tanks for your BBQ. Heavy when filled, light when empty.
Lol...Propane turns into a liquid form when compressed, that's why it is heavy -- the air we pump into the tires does not turn into a liquid form, not even when it's heavily compressed, like for a scuba diving tank (1000+ psi). So it weights nothing that we would notice.
So which is heavier: 1 ton of the softest cotton or 1 ton of lead?
Old May 1, 2006 | 03:50 PM
95snoozer's Avatar
95snoozer
very high pressure... like a nitrous bottle
liquid propane
not "air" at 30 psi
Old May 1, 2006 | 03:51 PM
95snoozer's Avatar
95snoozer
truck load of lead FTW, Bob
Old May 1, 2006 | 03:56 PM
Amarao's Avatar
Amarao
... Yes a tire will weigh more inflated vs deflated. You are increasing the density of the air inside the tire therefore it WILL weigh more. Not saying that it's a huge difference, but everything has weight so something full has to weigh more than something that is empty.
Old May 1, 2006 | 04:26 PM
Tenac1ousZ's Avatar
Tenac1ousZ
So you're saying 1 ton of lead is heavier than a 1 ton of Bounty-soft cotton?
But a hot air ballon weights more when it's empty than when it's full of helium
Old May 1, 2006 | 04:55 PM
95snoozer's Avatar
95snoozer
"truck load"
Old May 1, 2006 | 05:03 PM
Amarao's Avatar
Amarao
First off a hot AIR balloon doesnt use helium... it uses hot air, which is less dense than cold air and therefore is lighter. That is why you always see those balloons in the early morning while the air is still cold.
Old May 1, 2006 | 09:24 PM
Tenac1ousZ's Avatar
Tenac1ousZ
But an empty balloon is still heavier than a balloon filled with helium
Old May 2, 2006 | 10:39 AM
95snoozer's Avatar
95snoozer
you are joking right?
please tell me you are joking!
Old May 2, 2006 | 10:40 AM
95snoozer's Avatar
95snoozer
we should all run helium in our tires so they are lighter
Old May 3, 2006 | 02:18 AM
paikman's Avatar
paikman
-edit
damn the oem bridgestones are heavier than i thought
so its about 5lb difference filled and unfilled
Old May 3, 2006 | 02:26 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Originally Posted by paikman
-edit
Lol...No, I think it's closer to 3.5 lbs more per tire with air filled in them -- I weighted the bucket of air myself.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
